KZ750 Keihin CV34 float bowl o'ring gasket
  • undiablo
  • undiablo's Avatar Topic Author
10 Mar 2013 20:32
#576417
Hi guys!
I think this will be usefull to a lot of KZRiders.
If you want to replace the float bowl gasket of your Keihin CV34, all you need is a set of 4'rings size:
67mm ID
2,5mm section
Material: Nitrile Acrile or Buna N
You can buy it at and industrial store for less than 10 USD the 4 of them, instead of 22 USD at Feebay. :P
See attached pictures.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
The following user(s) said Thank You: Nessism, Britbiker
  • mopguy
  • mopguy's Avatar
Re: KZ750 Keihin CV34 float bowl o'ring gasket
10 Mar 2013 20:37
#576418
They look like the rings you get with oil filters?
  • undiablo
10 Mar 2013 20:55
#576423
Similar, I do not really know the size of the oil filter o'ring.
  • JR
  • JR's Avatar
10 Mar 2013 21:37
#576431
Very Very interesting.
Thanks for posting.
Now I just have to find an industrial supply store which sells o rings. I have tried the genuine Kawasaki float bowl O-rings (expensive) and just like the cheap ones they swell up when I take the carb bowls off . I think it's the alcohol in the gas
  • undiablo
10 Mar 2013 22:09
#576442
You might try using VITON o´rings. But for sure the will be more expensive than genuine Kawasaki.
Another things is not to over torque the float bowls JIS bolts. This may you press to much the o´rings. Just tighten to the point the o´rings seal.
  • Britbiker
  • Britbiker's Avatar
17 Mar 2013 00:39
#577311
Good idea ,Can I ask you what did you use to clean the inside of the float bowls ?
Keith
  • undiablo
19 Mar 2013 19:09
#577730
Just soak them for 30 minutes in carb cleaner. Interior looks amazing, exterior could receive a good polish though.
  • dvnsta
  • dvnsta's Avatar
17 Oct 2016 11:42
#745440
This archived post has size cannot figure out how to link it.
1982 KZ 750 LTD H3 stock except with custom seat skin and kawasaki period backrest.
Kawasaki 1989 eliminator 250 b3
  • Nessism
  • Nessism's Avatar
  • Away
  • dvnsta
  • dvnsta's Avatar
17 Oct 2016 16:59
#745487
I live three blocks from that store going to measure the rest of the o rings for the kiehin cv34 and go get bulk a quantity of each lsst tome i buy kits on the auction site were i dont know the quality of product. Will have to buy quantities of each as they are so cheap each and the store has a 5.00 dollar minimum for walk in customers.
  • Nessism
  • Nessism's Avatar
  • Away
17 Oct 2016 19:59 - 18 Oct 2016 11:35
#745508
dvnsta wrote: I live three blocks from that store going to measure the rest of the o rings for the kiehin cv34 and go get bulk a quantity of each lsst tome i buy kits on the auction site were i dont know the quality of product. Will have to buy quantities of each as they are so cheap each and the store has a 5.00 dollar minimum for walk in customers.
I've figured out the various O-ring sizes for those Keihin's:
Pilot Screw: 1.2 x 2.6
Pilot Plug: 1.5 x 2.8
Fuel Transfer Tubes: 2.0 x 5.5
Drain Screws: 1.4 x 4.0
Regarding the float bowl O-ring, I measured the groove this evening and it shows 1.5mm deep and 2.37mm wide. I think the 2.0 mm wide O-rings would be plenty fat to fill the groove but I'm not positive. I'm going to place an order and pick up a few 2.0 and 2.5's to see which I like best.
Last edit: 18 Oct 2016 11:35 by Nessism.
The following user(s) said Thank You: dvnsta
  • dvnsta
  • dvnsta's Avatar
18 Oct 2016 13:46
#745607
Thanks for the size info saves a lot of cash just having this info.
