Sync Question
  • Spectre1982
  • Spectre1982's Avatar Topic Author
Sync Question
26 Jun 2012 18:20
#531959
Just recently got my bike running on all cylinders. I noticed that I get different temps at each header. Cyl 1 was around 250; Cyl 2, 250; Cyl 3, 400; Cyl 4 350. It wasn't completely warmed up, just testing it out.
Could this arise from the carbs not being synched properly? After the last cleaning, I'm pretty sure the carbs are spitting plenty of mixture.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
  • faffi
  • faffi's Avatar
Re: Sync Question
27 Jun 2012 03:44
#532044
If your carbs are out of sync, all cylinders will not pull equally. Those that do the most work will also be the warmest. So if you have cleaned them and there are no air leaks, I would definitely suspect carbs out of sync. Just make sure that the spark plugs are good and valve clearances are within spec first as these things affect synching.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
The following user(s) said Thank You: Spectre1982
  • Spectre1982
Re: Sync Question
27 Jun 2012 11:46
#532088
Still been too busy to remove the head and check the valve clearances. Also, my feeler gauges only go down to .06. I need a thinner set. I've got a huge list of maintenance items I still need to address. The bike hasn't been out of the garage in 8 years so it needs it all. I'm hoping the valves are in spec considering there's less than 10k on the motor, but I've had issues every step of the way. I'm sure I won't get off that easy!! Lol
Thanks everyone!
1978 Kawasaki KZ200
