Hopefully these are simple fixes;
Firstly;
float levels are correct
carbs have been bench sync'd & then fine sync'd on the bike
Air screws are 2 turns out
Valve clearances have been checked
Running an ELECTRONIC ignition
Fuel is Super Unleaded (97 Octane here, ordinary stuff is 95 octane)
Carbs are fully cleaned (Ultrasonically & vapour (wet) blasted)
All airways are clear & so are the jets
#50 pilot & #135 mains (running Pod filters & baffled but short end cans)
Compression is good & well within spec
Plug gap set to 0.72mm (0.7-0.8mm for spec)
Now you may be wondering why i mention so much about the carbs in an engine thread, it may be related to both??
So i got her fired up to balance the carbs on the bike & i have a few issues;
1/ Backfires when coming down the revs on the right cylinder
2/ Left cylinder running hotter than the right. I have heatwrap on the exhausts & you can grab the right header when the bike has been running about 5 mins, you can touch the left header but you wouldnt want to hold onto it.
3/ Right cylinder makes a kinda phut-phut-phut noise when warmed, i wouldnt call it popping unless maybe its very quiet kinda popping
4/ Takes a while to return to idle (1000RPM), when i rev itthe RPM comes down quickly enough to 1300 RPM but then takes about 20 secs to return to idle speed
Does this sound like i need to check the timing?
Or would the valves on the right cylinder be 'coked up' & stopping shutting properly?
OR maybe valve stem seals?
Here are the plugs after about 10 mins of running at idle & a few light revs. Pics are taken with & without flash but its hard to show a true picture. The RIGHT cylinder was more sooty than the left to the naked eye
Right Plug (bit of a bad 1st pic) & may have gotten the non flash pics mixed up but you get an idea of the sooty deposits
Left Plug
