hanging rpms
- bromz
- 1981 kz1000 csr
hanging rpms
13 May 2012 17:47
I know this has been discussed many times but im stuck. Bike was running great then my petcock started leaking. I replaced it with a pingle on off res got rid of the vacuum. everything is the same except i plugged number 2 carb where the vacuum line was going to the petcock. (i have tried every combo there is even completly removin the epa clean air system. Bottom line bike idles great blip throttle rpm go to 4k and stay. blip it one or two times they return. replaced carb holder boots. They had cracks new boots from airbox to carbs. checked for vac leaks with wd 40 no leaks. checked all spark plugs and they are all firing. throttle isnt sticking visually watching it return. I have a little bit of backfiring through carbs and when i shut the bike down out the exauhst pipe once. carbs have been cleaned twice this spring and synced. please dont tell me i have to clean them again. im just missing something. help please
1981 kz1000 csr
1981 kz1000 csr
- peter1958
Re: hanging rpms
13 May 2012 18:01
Only thing I can think of would be the throttle grip hitting controls. Sounds like you have coverd everything
www.kzzone.com/
- vintagebiker
Re: hanging rpms
13 May 2012 19:58
There is one thing you haven't checked. The mechanical advance under the ignition cover. Make sure the springs and advance cam aren't sticking or broken.
If the exhaust is popping you have an air leak or lean mixture some where.Plugged idle circit jet.
Carbs not synced properly will do this as well. But sounds like you have checked all those things.
Make sure you have free play at throttle when grip is at rest at least an 1/8 of an inch movement.
If all else fails, JUMP!
- MFolks
Re: hanging rpms
13 May 2012 20:49
Tried the UNLIT propane torch? The gas will make leak finding much cleaner than giving the carb holders & boots a bath in WD-40.
- bromz
- 1981 kz1000 csr
Re: hanging rpms
13 May 2012 23:19
so i lubed the throttle itself and was gonna adjust the free play. what does free play mean? the throttle rolls 1/8th inch before the butterflys react? my throttle doesnt roll at all with out the linkage moving. then gonna work on greasing the advancer as soon as i can get it apart
Re: hanging rpms
13 May 2012 23:24MFolks wrote: Tried the UNLIT propane torch? The gas will make leak finding much cleaner than giving the carb holders & boots a bath in WD-40.
Carb cleaner works great too. No oily mess. Ed
- elfmagic17
Re: hanging rpms
14 May 2012 02:16bromz wrote: so i lubed the throttle itself and was gonna adjust the free play. what does free play mean? the throttle rolls 1/8th inch before the butterflys react? my throttle doesnt roll at all with out the linkage moving. then gonna work on greasing the advancer as soon as i can get it apart
Ya sounds l;ike you need to loosen yout throttle cables a little.
Kenny Hicks
74 Honda CB550
74 Honda CB550
- bromz
- 1981 kz1000 csr
Re: hanging rpms
14 May 2012 23:37
Well guys it was a simple one. I had the gas tank on and off a dozen time not paying attention the throttle cable was pinched under the tank! Thats the reason i couldnt get any free play also. So all is good and back to normal! (FOR NOW) Thanks for all your help
- donthaveakawman
Re: hanging rpms
25 Mar 2013 22:17
sync the carbs? idle adjuster screw also. carb work basically is my best guess.
