Drag strip trip. 27 Dec 2015 04:08 #704494
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
Stack of time slip's from here at the house there's still more at the
shop, in the van and my tool box at work. 127 pass in this stack.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: by zukdave.
Drag strip trip. 27 Dec 2015 07:22 #704523
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
About time you rebuild your engine, :laugh: :laugh:
Pete
Drag strip trip. 27 Dec 2015 12:23 #704566
  • zukdave
I think I've got about 50 pass on the rebuild
Some of these go back to when it still had the 650 motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 11 Jan 2016 16:09 #706366
  • zukdave
Track reopens for this year next Sat. :) :)
Sucks this is my month to work Sat. and I can't go :( :(
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 19 Jan 2016 14:28 #707292
  • zukdave
Been thinking about how to deal with the wheelie issue I really
don't want to put the bar back on and talking with a few buddy's they all say
put shock's back on it so I'm gonna rework the lower mount's and and see how it work's.
Not got a clue right now about spring rate or dampening so I think I'm going to use the stock ZRX
shock's I have to get a base line setup.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 23 Jan 2016 06:34 #707727
  • kawi810
  • kawi810's Avatar
  • Thank you received: 11
looks like Gumpy G is going to make more lock up clutch kits available.that should finish off your drag bike.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
Drag strip trip. 24 Jan 2016 10:24 #707880
  • zukdave
kawi810 wrote: looks like Gumpy G is going to make more lock up clutch kits available.that should finish off your drag bike.
I'll have to check into that thanks.
Can't go run the bike right now so I'll get my fix with grudge race video's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 28 Jan 2016 14:12 #708400
  • zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 30 Jan 2016 14:21 #708613
  • zukdave
All you folk's that have been following this thread I want to say THANK YOU !!!!!!!
When I started it I didn't think about it lasting for what coming up on four year's now
and reaching 35,000 + view's it was just me talking about taking the GPz motor swap to the track for the first
and has turned into the history of me drag racing this little bike.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 30 Jan 2016 14:30 #708615
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2609
Those of us that don't have the opportunity to do like following the ones that can. Keep it going. :cheer:
Drag strip trip. 30 Jan 2016 14:33 #708616
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Love it ....A crap load of those views are from me I'm thinkin ...... has been my go to thread when I'm bored or need some insperation .....started looking through it again the other day and got to page 10 I think it was..... will finish it off again soon I'm sure.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Drag strip trip. 30 Jan 2016 15:08 #708621
  • zukdave
KZB2 650 wrote: ..started looking through it again the other day .
I did that the other night and read it all it's cool to go back and see how the bike's changed over the year's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
