  • Page:
  • 1
  • 2
Kz 1000 offset sprocket 26 Mar 2023 09:25 #882013
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
A few years ago I was looking for sprockets and if I remember correctly some Suzuki front sprockets use the same spline shaft pattern. Might help expand your search.
EDIT; This evilbay listing seams to back up my memory item number 255962718842
          This listing states he has several offsets and chain sizes in stock, and has the ability to make any custom sprocket you need. Item # 255517388701
Last edit: by Mikaw.
Kz 1000 offset sprocket 12 Apr 2023 16:11 #882990
  • rivman15
  • rivman15's Avatar
  • Thank you received: 19
Southpaw, How did you make out with this?
Kz 1000 offset sprocket 05 Feb 2024 11:46 #894894
  • ez_goin112
  • ez_goin112's Avatar
  • Thank you received: 3
I bought my front and rear offset sprockets here.
www.americanclassix.com
They are still around as of 2/5/24.
Kz 1000 offset sprocket 30 Mar 2024 11:45 #897077
  • Tolon
  • Tolon's Avatar
  • October 14
On mine, I believe I used a sprocket off a mid 90’s zx11r using a 530 chain
1982 kz1000k (my baby)
82 GPZ1100piston/cyl
84 GPZ1100 head/cam
01 sv650 fork swap with cbr F4 internals/gsxr calipers & master cylinder
05 gsxr600 swing arm/monoshock
GM HEI ignition module swap
Full custom wiring and control setup
1980 kz1000g
1995 kz1000p
  • Page:
  • 1
  • 2
