  • Page:
  • 1
Picked up a new to me compressor 15 Jan 2015 13:39 #658786
  • KZJOE900
  • KZJOE900's Avatar Topic Author
  • Admin
  • Thank you received: 443
Just brought this home yesterday from HF. This was a returned item which I was able to purchase for dirt cheap. My old 125 psi 3.5 HP dry compressor was not good for everything I needed to do and it needs a new pressure cutoff switch replacement which is about 65 bucks to order. I'm sure I replace just the pressure sensor / switch for much less, but this came along and it just made sense. Could easily paint a bike with this compressor. It will not handle the professional grade spray guns (10 CFM or more), but at 7.3 CFM @ 40 psi it will handle the intermediate level guns. And if the gun is a good quality, I should give excellent results.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Picked up a new to me compressor 16 Jan 2015 05:41 #658822
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2674
Good for you. Looks like a piston compressor. Much better than those crappy "oilless" scroll compressors.
The following user(s) said Thank You: KZJOE900
Picked up a new to me compressor 16 Jan 2015 07:27 #658828
  • KZJOE900
  • Admin
Its two cylinder. This is a returned unit checked out by the store. So I only had to pay a hundred for it. But no warranty. Seems to work properly. I hope it was simply someone who decided to borrow it from the store for a couple of days and then return it.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Picked up a new to me compressor 16 Jan 2015 07:58 #658835
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2620
That happens. Buyers remorse or something more shady. I think the latter.
Picked up a new to me compressor 16 Jan 2015 14:17 #658858
  • moneypit
  • moneypit's Avatar
  • Thank you received: 35
Dang nice score. 250 off retail?
2-76 kz900
St Paul MN
Picked up a new to me compressor 16 Jan 2015 17:05 #658874
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
Yes, Nice score! Get a 20" box fan to cool it down! if your gonna use the hell out of it! For cooling.
Just what I have to do!
Picked up a new to me compressor 16 Jan 2015 17:12 #658875
  • KZJOE900
  • Admin
Nice compressor and nice setup! Looks like you can get a lot of painting done without it needing to kick in. Wish we had basements down here. It would be a much needed retreat for me. Am I right to assume you have air lines piped to the garage?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Page:
  • 1
