  • Page:
  • 1
  • 2
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 09:39 #654510
  • pertonpc
  • pertonpc's Avatar Topic Author
  • Thank you received: 3
Hello All,
This came in my Z1-R tool kit -
I don't think it belongs to that bike, it is not marked with any manufacturer details - just MADE IN JAPAN.
Other side has no markings at all.
Can anyone tell me what it might belong to please?? :blink:
Thanks from Mark
Z1-R, Z650B and a Z1-B Catch 'em if you can at www.zedrider.co.uk
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 09:42 #654511
  • NakedFun
  • NakedFun's Avatar
  • Thank you received: 99
Fork cap? Maybe used with the spark plug socket.....? Shot in the dark.
GL
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 10:42 #654513
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
  • Thank you received: 62
My750 turbo had one in the tool kit ...Guessing it is for axle bolt?
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 10:49 #654515
  • LineArtist
  • LineArtist's Avatar
  • Thank you received: 35
1981 KZ550-D1 GPZ... from a Google search, perhaps many more models and years starting in the 80's.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 12:31 #654523
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
I used that to take the rear axle bolt on my 78 kz1000, I stuck a long pipe in the handle to get leverage .
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 14:07 #654532
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
The tool kit should also come with a piece that slips on the end of the wrench to act as a handle extension , for better leverage
Pete
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 15:37 #654539
  • turboking
  • turboking's Avatar
  • Thank you received: 106
as stated ,axle nut tool :ohmy: , also has a hollow sleeve for leverage.......
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
19 mm Wrench - What bike has this in the toolkit ? 24 Nov 2014 19:19 #654572
  • Thank you received: 2098
In the perhaps similar Z1 toolkit, #13 extension sleeve adds leverage to #12 rear axle nut.
Don't remember whether or not #13 also fits over #16 shock pre-load adjustment tool. :unsure:
Good Fortune! :)
The following user(s) said Thank You: !Seymore
Last edit: by Patton.
19 mm Wrench - What bike has this in the toolkit ? 25 Nov 2014 05:55 #654578
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Rear axle nuts on the big kzs and h2 are 27mm; so if thats what it is it's a litttle bike. My 550 is larger than 22 IIRC. So no idea
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: bikerguy
19 mm Wrench - What bike has this in the toolkit ? 25 Nov 2014 07:20 #654592
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
The tool is probably extraneous to the kit. From referencing the 1980 D3 owner tools diagram at Partzilla & an eebbaayy Z1R tool kit, I think the kit should have a 27mm box end wrench (which is probably for the Rr axle nut). From the wheel bearing sizes, the front axle nut wrench is probably bigger than 19mm. ???
19 mm Wrench - What bike has this in the toolkit ? 25 Nov 2014 08:19 #654594
martin_csr wrote: ... Rr axle nut[/i])....
Interesting reference as to which side the rear axle nut is placed.
Some put it on the right side.
Others put it on the left side.
Rear axle nut on muffler side --
May allow removal of the axle without interference by the muffler.
Rear axle nut on non-muffler side --
May disallow removal of the axle unless muffler is moved out of the way.
Rear axle nut on right-hand (starboard) side --
Forward wheel rotation encourages loosening of the nut.
Rear axle nut on left-hand (port) side --
Forward wheel rotation encourages tightening of the nut.
In any event, would suggest using a hitch-clip pin to secure the axle castle-nut, instead of the more common skin-slicing rag-grabbing cotter pin aka cotter key.
Good Fortune! :)
19 mm Wrench - What bike has this in the toolkit ? 25 Nov 2014 14:01 #654630
  • martin_csr
That is a sideways tangent. hee.
  • Page:
  • 1
  • 2
