Forum
  • Register
  • Page:
  • 1
TOPIC: Die Grinders
Die Grinders 4 years 11 months ago #515645
  • LarryC
  • LarryC's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 290
After porting with air for 30 years, I thought I'd give electric a try. I picked up a GE0600 a few months ago. Brushes are shot already.
I needed to keep moving so I went out and picked up a GD0601. The predecessor to the GE0600. Better grinder, more power, smoother.
Still, neither of those hold a candle to my ancient, 30 year old Blue Point Air grinder.
Larry C.
Die Grinders 4 years 11 months ago #515651
  • MFolks
  • MFolks's Avatar
  • Member
  • Member
  • Thank you received: 502
The only tools for drilling & riveting in aerospace work were air powered. Even the heat guns for doing heatshrink work were air powered(via a remote heating setup). There was fear that exposed sparks from the brushes could set off a fire/explosion from fuel or solvent exposure.
As you've found out, air tools are lighter,self cooling,and more user friendly than the electric ones are. Sure, they're pricey compared to the electric version, but they seem to last much longer.
Die Grinders 4 years 11 months ago #515653
  • les holt
  • les holt's Avatar
  • Thank you received: 219
We use air and electric grinders at work, air grinders are much nicer and last much longer. I sware by Atlas Copco and Dynabrade, more than a bit pricey but well worth it.
Les
Die Grinders 4 years 11 months ago #515672
  • jonnybravo
  • jonnybravo's Avatar
  • User is blocked
  • User is blocked
  • Thank you received: 18
agreed Lar, that plus , in general, makita aint what it used to be, die grinders and some others, (DA sanders , etc) must be air , problem with electric is the dust gets to the brushes so fast they're toast in no time, we use big ass 9 inch grinders with 10 inch diamond blades ( we remove the safety guards) to cut stone and we run into the same thing, fine dust toasting brushes, so instead of buying the expensive shit for 300 a pop I get Harbor Freights for 49 dollar, we tried taping off the air vent just for shits and giggles but it fried em even faster. :woohoo: :lol:
Last Edit: by jonnybravo.
Die Grinders 4 years 10 months ago #519903
  • 1100fighter
  • 1100fighter's Avatar
  • Member
  • Member
  • Thank you received: 3
I have a electric that kicks as$! It's a hitachi and has been used to drill 100s of holes in rock. It has impressed me. I've burned out other hitachi tools but this one has been a good one.
i244.photobucket.com/albums/gg22/yjcrawlr/photo-526.jpg
Throttle junkie since 5
Last Edit: by 1100fighter.
Die Grinders 4 years 10 months ago #519959
  • LarryC
  • Member
  • Member
1100fighter wrote: I have a electric that kicks as$! It's a hitachi and has been used to drill 100s of holes in rock. It has impressed me. I've burned out other hitachi tools but this one has been a good one.
Looks similar to an Chicago Electric that I have. Big draw back with electric grinders for porting is in how true the cutter will spin.
Larry C.
Die Grinders 4 years 10 months ago #519998
  • wireman
  • wireman's Avatar
  • Member
  • Member
  • Thank you received: 303
My hand gets cold running the air ones,yeah I know where gloves! :woohoo:
Die Grinders 4 years 10 months ago #520007
  • jonnybravo
  • User is blocked
  • User is blocked
the Hitachi is a better made tool anyway, Makitas quality ,in general, has fallen off over the years
Die Grinders 4 years 10 months ago #520036
  • jonnybravo
  • User is blocked
  • User is blocked
well if u think about it that makes total sense, the electric is driven by the electric motor with the brushes and armature thing and the electrical field is a friction based movement whereas the air is not, hence the increased smoothness factor correct ????/
  • Page:
  • 1
