Coil Spring Compressor Tool, any idea's?
  • 750steve
  • 750steve's Avatar Topic Author
02 Jan 2012 15:04
#495857
Has anyone made a shock coil spring compressor tool? If so would you mind posting pics of what you done? I dont really fancy splashing out £30 ($50 ish) on something i'm probably only going to use once
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • loudhvx
  • loudhvx's Avatar
Re: Coil Spring Compressor Tool, any idea's?
02 Jan 2012 15:59 - 02 Jan 2012 16:02
#495870
This is probably not cheaper if you have to buy everything. I had most of it accumulated over the years. The main reason I made it was that it was much faster than the compressor my friend had, and I was going to be doing a lot of spring swapping.
I only have one photo of it. Get the bracket from a large caster and take the wheel off. Use that as the lower mount for the shock. Attach it to a board and clamp the board to a table. It's hard to see in the photo, but there are actually 3 turnbuckles. Each one is held down with a "U" clamp mounted into the board.
Once the turnbuckles are set to the right length, it's just a matter of rocking the shock backward or forward to pull the spring down and slide out the retainer.
Later I replaced the "S" hooks with strapping material loops to prevent scratching the springs.
Last edit: 02 Jan 2012 16:02 by loudhvx.
The following user(s) said Thank You: 750steve
  • 750steve
02 Jan 2012 17:26 - 02 Jan 2012 17:26
#495878
Thanks Lou. I think im gonna see my friend with the CNC machne tomorrow night. I'll get 4 'claws' knocked up & use some M8 threaded bar with nuts & washers to compress them.
Either that or 2 claws & a flat plate with a 40mm hole & 2 M8 holes either side to put the bar through & grab the 'claws'. The only thing putting me off the 2nd descroption is i doubt every shock will fit into a 40mm hole.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 02 Jan 2012 17:26 by 750steve.
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
02 Jan 2012 17:26
#495880
I just did mine at home with some zip tie`s Its cold in the garrage.
  • 750steve
02 Jan 2012 17:27
#495883
Mine are off the bike Pete
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • jason8887
  • jason8887's Avatar
13 Jul 2012 23:17
#535767
done plenty of them with better quality hose clamps....
  • wireman
  • wireman's Avatar
13 Jul 2012 23:53
#535772
I live dangerously and just put the bottem eye between my feet and use 2 screw drivers to compress spring while somebodt pulls retainer out,Ive been doing it for years and know how far i can push my luck though B)
  • Motor Head
  • Motor Head's Avatar
14 Jul 2012 01:18
#535784
Just changed the springs on mine today. used the press. It took a couple of seconds each. Upside down in the press, two blocks on the side, lined up with the outer edge of the retainer shroud. You can slip the keeper out, then release the press, change the spring and the do it again for reassembly.
  • wireman
  • wireman's Avatar
14 Jul 2012 11:23
#535832
Show off! :laugh:
  • Old Man Rock
  • Old Man Rock's Avatar
14 Jul 2012 11:30
#535837
Car Strut tool may work.... ;)
Can borrow from most Auto Parts stores...
or HFT, cheap.... HBT Strut Tool
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Motor Head
14 Jul 2012 11:37
#535840
Another easy way. You can do the Zip Ties, (good ones), or mechanics wire, like suggested.
Compress the rear suspension, and use a Motorcycle tie down strap or ratchet strap to pull it down. place the bike on the center stand, or put a jack under it. Once compressed do the ties on the springs. Then unbolt the shocks.
  • trianglelaguna
  • trianglelaguna's Avatar
14 Jul 2012 11:51
#535842
my teeth
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
