in that link there was an adapter fitting on top of that right cover. is there also a fitting below that as well?>
79MKII wrote:
I tried to look up your bike on bikebandit... I didn't see a listing for an MKII?? If you have a parts breakdown for your bike, compare it to other KZ1000's and 900's and see if the part number is the same for the oil gallery bolt or block off bolt. I have fitted many of those adapters on KZ900, KZ1000 and Z1's 74-80. They have all been 1.25 thread.
I have learned that some of the Kawis have 1.25 threads, some have 1.50 threads. You have the wrong adapter. I sent you an email requesting your address, and I will send you the right adapter, no charge. Sorry for the mix-up.
Good idea with the oil temp set up. Thanks for the tips.
