  • Page:
  • 1
  • 2
Oil filter 17 Feb 2024 10:11 #895356
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2708
So, what's important is for you to tell us about that wall heater!
Oil filter 17 Feb 2024 11:40 #895358
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Well interesting you'd inquire! The best heater ever, it's a radiant heater!! Don't even need the "optional" fan option. Had my HVAC fella plumb it, gas line drip pipe and all. A couple years ago we had temps that had fallen below 0, actually -30deg. I could still sport my normal attire of shorts and flip-flops. Still a standing 85+degrees in "this" attached garage. When we first bought this 3800sq ft hillbilly shed the rafters previously uses were 2x4's and bowed. Knocked all that shite out and put proper 6x2's for the rafters and i insulated the crap out of it. Re-wired it placing outlets placed for handy access and implemented LED fixtures for focal points of workstations. 4x the beam of 2x12's shouldering the weight of engine shown with similar supports on each end. Suppose i garnered my knowledge from lifting houses-up off their foundations and dropping the haydite/mortar/concrete block existing foundations and setting-up forms for a poured foundation. Used to build cooler and freezer pads and foundations for Hussman Refrigeration, and remedial water tower bases for of placement silos of waste water that can't immediately be flushed into the city's managed GPH piping. Got carried away but.. Yes these birds work Fantastic.
Oil filter 17 Feb 2024 17:27 #895366
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2091
“lifting houses-up off their foundations and dropping the haydite/mortar/concrete block existing foundations and setting-up forms for a poured foundation”
Ha! I wore that t-shirt for a time.
Oil filter 19 Feb 2024 03:27 #895416
  • asphalt900
Nothing like the smell of form release oil, or taste if gets in your coffee, early in the morning, ha.
Oil filter 19 Feb 2024 13:34 #895437
  • TexasKZ
  • TexasKZ's Avatar
We used diesel
Oil filter 19 Feb 2024 20:57 #895451
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 315
My old boss used molasses for form release.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Oil filter 20 Feb 2024 03:20 #895456
  • asphalt900
Diesel makes sense but molasses? Were you fella's still hung-over from the night before and just confused and used the condiments that came with your McGriddle breakfast sandwich, ha.
Oil filter 20 Feb 2024 18:06 #895470
  • TexasKZ
  • TexasKZ's Avatar
Molasses had to have smelled a lot better, but seems like it would attract every ant in the county.
  • Page:
  • 1
  • 2
