Just a cautionary note... find the pieces!
I've seen enough engines /vehicles damaged from parts and tools "gone missing". Some of the best where:
An FJ1200 drag bike that had a no. 2 Phillips screwdriver magnetic bit embedded through the dome of piston #3,
A 4.0 L Ford Ranger with small pieces of broken spark plug porcelain embedded in the head and piston (bent valves too),
A CB550 that had a head sealing washer remove several teeth from various transmission gears - I found the washer and the bits of gear teeth in the sump when I dis-assembled the engine,
A "fresh rebuilt" Yamaha Raptor 350 quad with a M6 x 10 Phillips screw wedged between the crankshaft and crankcase,
A Cummins Select Series 500 HP truck diesel engine with broken timing gear from a 1/2" drive x 12" extension dropped into the timing / accessory drive cover,
A Honda CB350 that sucked up small pieces of a chewed up "extra" piston ring cir-clip into the oil pump....
A 3.3 L Dodge V-6 with the broken off dip stick wrapped around the crankshaft,
3 (!) valve keepers stuck to the rotor magnets of a KZ1000J
And the winner - A Ford L9000 highway tractor that spent frustrating and costly days in our shop after arriving by tow truck because it would run, then die, then run again, then die...classic case of fuel starvation...
No one could figure out the problem until one mechanic said something about how clean the inside of the fuel tanks were - the printed part number inside of the fuel tank still being visible by looking into the filler neck with a flashlight. I asked what the hell he meant, so he showed me. It wasn't the part number of the tank he saw - turns out the driver had replaced the alternator belts only a few hours before the problem first occurred. When he was done, he just discarded the plain tan colored cardboard sheath the new belts came packaged in on the ground in the truck stop parking lot. A conscientious homeless bum loitering in the parking lot observed this and, obviously not impressed with the driver's littering habit, gave the driver a malicious stare... but he wasn't quite finished yet. He must have waited until the driver went into the restaurant for dinner before dispensing additional justice....
It only took a few minutes with a flashlight and coat hanger to fish out the now clear (as in see -through) diesel fuel soaked cardboard sheath hovering around at the bottom of the tank and intermittently blocking the fuel outlet fitting - the "tank part number" was actually the belt part number stamped in black ink on the cardboard....
