What size Piston kit to run with Mr Turbo kit 14 Aug 2016 05:16 #738609
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Hello all What size piston kit would you run with a Mr Turbo Kit on a 1977 KZ1000 LTD. I was thinking about a 1327 MTC kit. Did not know if I would have overheating issues or not since the compression was low on the turbo pistons. Any Help Appreciated!
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 05:49 #738611
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Cylinder wall ridigity and cooling should be your biggest concerns.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 06:58 #738618
  • jumbulias
I know if I go with the 1327 kit I would have to get a big block. Is anyone runnnig a 1327 Turbo? I want this for street not drag. Should I opt for something smaller?
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 08:39 #738622
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
1075 is plenty.
1984 750 Turbo
The following user(s) said Thank You: PLUMMEN
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 09:47 #738625
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1983
I run a 1075 MTC piston set on my Turbo bike.. 7.8 to 1 ratio purchased thru Joe Hopper at Pit Stop Performance in FL.
I sent him the cylinder block and he bored the holes for each piston based on their actual individual size and gapped the rings too
Cant beat his prices and I have had excellent service
Dave B) B) B)
Next you should think about having the cylinders o ringed and use copper head gaskets , APE studs and nuts We can talk more if you need advise based on over 30 years running a Mr Turbo kit.
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 12:31 #738632
  • jumbulias
Thanks for the info Does this bike look familiar . I call her Black Beauty This is my 1978 LTD
Last edit: by jumbulias.
What size Piston kit to run with Mr Turbo kit 14 Aug 2016 18:33 #738685
  • Moderator
jumbulias wrote: Thanks for the info Does this bike look familiar . I call her Black Beauty This is my 1978 LTD
Ahh Yes :P
Brings back memories of where life began ;)
Dave B) B) B)
Now mine looks like this
Mine is called SUZIE B)
Last edit: by Street Fighter LTD.
What size Piston kit to run with Mr Turbo kit 25 Aug 2016 13:10 #739922
  • jumbulias
I just sent the cylinder block to Joe Hooper. He recommended the MTC 1197cc Kit . Along with getting the Crank welded and indexed. He is also going to do the Transmission. Going to have the Head redone by Larry C. Going to order the Mr Turbo kit next week. I have been wanting to do this since I was 18 years old. I cant wait.
What size Piston kit to run with Mr Turbo kit 26 Aug 2016 01:19 #739990
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
jumbulias wrote: I just sent the cylinder block to Joe Hooper. He recommended the MTC 1197cc Kit . Along with getting the Crank welded and indexed. He is also going to do the Transmission. Going to have the Head redone by Larry C. Going to order the Mr Turbo kit next week. I have been wanting to do this since I was 18 years old. I cant wait.
1197 in a re-sleeved stock block is about as big as you can go and still hope for any kind of streetability....it is still going to heat up big time - get a big oil cooler on that somehow....ask Street Fighter LTD about all the do's and don'ts of running a turbo street bike (special considerations like never shut off when turbo is too hot, what oil to use and change how often, etc...).
Check out Old Kaw Man website, specifically his words on performance modifications and oil cooler installation.
Larry C's cylinder head work is a very wise choice....do as he says....
Last edit: by Kray-Z.
What size Piston kit to run with Mr Turbo kit 03 Sep 2016 13:43 #740992
  • jumbulias
Mr Turbo Kit Ordered 8-10 week wait. Also found the 1983 GPZ1100 Camshafts Larry C recommended. !
What size Piston kit to run with Mr Turbo kit 04 Sep 2016 09:51 #741065
  • jumbulias
Here is a couple of Pics of the !977 body Set. Painted by WFO .
Re:What size Piston kit to run with Mr Turbo kit 04 Sep 2016 10:14 #741066
  • Julian_Boolean
  • Julian_Boolean's Avatar
  • Thank you received: 8
In the late 80s I knew someone who had a 1978 Z1000 with a 1400 big bore, turbo and nitrous, it made 236 bhp, he's probably still got it but I haven't seen him since 1989.
