  • Page:
  • 1
PMFR Clutch release plate 27 Jan 2016 08:42 #708287
  • barney
  • barney's Avatar Topic Author
  • Thank you received: 36
I have a PMFR clutch release for my kz1000J motor but no hardware. Can anyone tell me what length the spacers are needed to mount it?
Barney
PMFR Clutch release plate 27 Jan 2016 10:23 #708301
  • davido
  • davido's Avatar
  • Thank you received: 286
are you taking about a hydraulic clutch conversion? If so,I think it would depend on what slave cylinder you are using. I also have to sort this out on mine and was wondering how to go about it.So far,the best I can come up with is trial and error.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
PMFR Clutch release plate 28 Jan 2016 04:50 #708355
  • barney
No .Manual cable operated
davido wrote: are you taking about a hydraulic clutch conversion? If so,I think it would depend on what slave cylinder you are using. I also have to sort this out on mine and was wondering how to go about it.So far,the best I can come up with is trial and error.
PMFR Clutch release plate 28 Jan 2016 08:54 #708375
  • davido
  • davido's Avatar
OK,it should be easy enough to measure from the original set up then,if you still have it .But then again,Im only guessing as I thought that these plates were for hyrdaulic conversions.If thats not the case,then Im missinformed and have no idea what Im talking about.So I would advise you to ignore anything I say!
Good luck with it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
PMFR Clutch release plate 28 Jan 2016 12:09 #708386
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Barney,
Somebody at Scnitz or Star may know since they specialize in such things.
PMFR Clutch release plate 28 Jan 2016 12:10 #708387
  • TexasKZ
  • TexasKZ's Avatar
Davido,
It is a plate similar to what you made, but for the factory release mechanism. Drag racers like them because they are light and allow easy access to the front sprocket between runs.
Last edit: by TexasKZ.
  • Page:
  • 1
