  • Page:
  • 1
Oil on front of the motor 27 Sep 2015 15:31 #692202
  • 76KZ900
  • 76KZ900's Avatar Topic Author
  • Thank you received: 5
Noticed oil on the front of the jug. It appears to be lower part of jug near base gasket. Is there any other source of oil near three. I've pretty much ruled out the valve cover gasket. It looks dry near there. 83kz1100. Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
Oil on front of the motor 28 Sep 2015 05:19 #692278
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
A small amount of oil got past my APE tensioner bolt/nut/o-ring, and migrated atop the second cooling fin to the front. To clean it up I squirted about a half-cup of gas on the fins around the tensioner, using an old turkey baster with a piece of 1/4" vinyl hose stuck on the end (when the engine was completely cool), in a breezy-shady area outside where it could easily evaporate. I'm not sure why, but the leak hasn't come back since...
1982 KZ1100-A2
Oil on front of the motor 28 Sep 2015 06:24 #692292
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
I don't know if your bike has a mechanical tach or not, but many times they will start leaking & oil will run down the front of the motor,
you can try to narrow down where the leak is coming from by cleaning the oil off the front of your motor & let it dry or dry it off, then get some talcum powder or baby powder & shake it on the front of your motor then start it up & see where the powder turns oily & where the leak is, the powder will turn brownish where the leak is coming from, & the powder can then just be hosed off
Pete
The following user(s) said Thank You: PLUMMEN
Oil on front of the motor 28 Sep 2015 07:00 #692297
  • aphex
  • aphex's Avatar
  • Thank you received: 0
pete greek1 wrote: I don't know if your bike has a mechanical tach or not, but many times they will start leaking & oil will run down the front of the motor
+1 ... this happened on mine. There is an o-ring on the fitting that mates into the head (maybe 2, can't remember)...I found a perfect replacement in the assorted o-ring kit sold by Harbor Freight. For 8 bucks or so, that kit has been a life saver!
1980 KZ1000 G1 Classic
1982 Yamaha XZ550, decommissioned
Oil on front of the motor 29 Sep 2015 20:32 #692568
  • 76KZ900
Thought about the tach cable after I posted. It's electric tach.. I'm guessing there has to be a sensor somewhere though. I did use some engine cleaner on front of motor and hosed off. I'll check my stock cam chain tensioner on my days off. Are base gaskets an issue on the 1100's ? Thanjs
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Oil on front of the motor 29 Sep 2015 22:38 #692571
  • daveo
  • daveo's Avatar
  • Premium Member
76KZ900 wrote: Thought about the tach cable after I posted. It's electric tach.. I'm guessing there has to be a sensor somewhere though. I did use some engine cleaner on front of motor and hosed off. I'll check my stock cam chain tensioner on my days off. Are base gaskets an issue on the 1100's ? Thanjs
I haven't had a leaking head or base gasket since HD APE Cylinder Studs were installed. Before that though...twice both. :pinch:
1982 KZ1100-A2
Oil on front of the motor 30 Sep 2015 09:10 #692618
  • pete greek1
76KZ900 wrote: Noticed oil on the front of the jug. It appears to be lower part of jug near base gasket. Is there any other source of oil near three. I've pretty much ruled out the valve cover gasket. It looks dry near there. 83kz1100. Thanks
If not already done you can also try re torqueing your cylinder bolts to the proper torque setting in the proper tightening sequence according to your manual
Pete
Oil on front of the motor 11 Oct 2015 16:33 #694195
  • 76KZ900
I did in fact re torque head. A few needed to be tightened. I cleaned motor and it appears oil is coming from somewhere in the middle of jug. Base gasket looks dry. So im going to look at cam chain tensioner on my next days off. I had pulled oil pressure sensor base off before thinking it was leaking, and it looks like it still is even after new o rings were installed. So now I'm thinking it was cam chain tensioner all along.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • Page:
  • 1
