  • Page:
  • 1
Possible exhaust leak 19 Mar 2015 13:22 #664944
  • mithrander
  • mithrander's Avatar Topic Author
  • Thank you received: 0
I am fairly sure my # 2,3 cylinders may have an exhaust leak/issue. 4:1 pipes seem loose at the head and can be moved a little. I have removed the pipes and found that some of the studs need replacing so I have ordered a whole new setup. I have the head off for some other inspection work and took the attached pics. Shouldn't the exhaust port be solid all the away around? Mine seem to have some degradation off the collar. Not sure if this is broken or ??. If this is broken is there anyway to repair? Can thicker gaskets seal this? Any help is appreciated as always.
Attachment P1030444.jpg not found
Attachment P1030446.jpg not found
Possible exhaust leak 19 Mar 2015 14:23 #664949
  • moneypit
  • moneypit's Avatar
  • Thank you received: 35
Are you sure that there isnt a crush washer stuck there? Use a dental pick and see if it comes off, may be that simple.
2-76 kz900
St Paul MN
Possible exhaust leak 19 Mar 2015 14:34 #664950
  • mithrander
Actually I am asking about the gap in the upper right hand side. It appears to me that part of the heads exhaust port is missing.
Last edit: by mithrander.
Possible exhaust leak 19 Mar 2015 18:06 #664974
  • moneypit
  • moneypit's Avatar
Sorry my mistake. Were there crush washers in there? Did it sound like it leaked? You said they felt loose, was a washer in it? It dose look like its missing a bit of material, I would think if its was tight with the washer it would be fine.
2-76 kz900
St Paul MN
Possible exhaust leak 21 Mar 2015 15:14 #665132
  • chconger
  • chconger's Avatar
  • Thank you received: 14
mithrander wrote: Actually I am asking about the gap in the upper right hand side. It appears to me that part of the heads exhaust port is missing.
Yes I would agree. The exhaust port milling should have a continuous circular shoulder around it. Something happened there to take out a bite of metal in both # 2 & 3 ports.
I cant imagine what would do that.
Chris
1977 KZ 1000-A
Last edit: by chconger.
Possible exhaust leak 22 Mar 2015 16:14 #665255
  • mithrander
I suspect both these exhaust ports had a leek. The head has now been removed. I am trying to decide if this head is trash or if it can be saved. Any suggestions. The original exhaust seals are of unknown condition as I just bought the bike. I have ordered a set of thicker seals 5mm vs. the stock 3mm all new hardware etc. I believe the valve seals are also bad but I do not want to spend any money on the seals if the exhaust ports are beyond repair
Possible exhaust leak 22 Mar 2015 18:16 #665282
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
With new gaskets it will seal as long as 1/4 are OK and it is a 4/1 header. It could be welded but you have other things to worry about.
Re:Possible exhaust leak 23 Mar 2015 05:49 #665331
  • KzChop82
  • KzChop82's Avatar
  • Thank you received: 7
It almost looks like the bike went over a speed bump and the exhaust got pushed up and snapped portions of the casting.
I did this one time and luckily I just snapped one of the mounting posts.
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • Page:
  • 1
