Hello all,
I recently pulled the valve cover and checked the valve clearance on my bike. I replaced a couple of the exhaust shims to bring clearance within spec. After putting everything back, the bike doesnt want to stay running. It is difficult to start, will not hold a steady idle. Once it is running the rpms ramp up to between 3500 and 4000 and hold until the engine is shut off. I pulled the valve covers and cams to make sure that I got the timing correct and put it back together. Still doing the same thing. Now a couple days ago I had to ride it home as the garage I was using had to be cleared. The ride home was rough to say the least. I think I may have done some damage to the engine. There was a lack of power on the ride, the engine was pulsing and had a difficult time staying steady at any rpm. Low rpm it seemed like it was misfiring, high rpm sounded like the engine was straining. Then I started hearing some knocking, sounding like something broke in the engine.
I know I should have ridden it, but had no choice beyond leaving it on the side of the road in a rough neighborhood. I am afraid I may have just killed my bike. I am beyond my knowledge level for repairing the engine. As I also live in an apartment with no garage, I have no way to try to do any more work myself.
So my question is, have I just destroyed the engine of my bike beyond what is worth repairing? I will need to take it to a mechanic for repairs. Is it worth any potential cost to repair the bike?
Thanks
