  • Page:
  • 1
Oil Pan Gasket Removal ??? 22 Oct 2014 14:51 #651434
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
  • Thank you received: 13
About ready to remove the oil pan off my 77' KZ1000A to change out the gasket and inspect. Can I remove the oil pan without removing the engine? Looks like you can, but wanted to make sure?
77' KZ1000A
Oil Pan Gasket Removal ??? 22 Oct 2014 15:45 #651441
  • turboking
  • turboking's Avatar
  • Thank you received: 106
Yes ....you can remove the oil pan with the engine in the frame . :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Oil Pan Gasket Removal ??? 22 Oct 2014 15:46 #651442
  • Zephyrrider
  • Zephyrrider's Avatar
  • Thank you received: 50
Yes.In your WSM do you have orings for the oil paths inside pan cover ? You MUST locate these correctly, ZR.
Mick
1994 ZR750 Zephyr C4.
Oil Pan Gasket Removal ??? 22 Oct 2014 19:54 #651469
  • kzdcw
  • 77' KZ1000A
I see one inside the oil pan. Is that the one your making reference too? It's a 91mm o-ring that sets inside the groove inside the oil pan? I have one on order with Z1 Ent.
77' KZ1000A
Last edit: by kzdcw.
Oil Pan Gasket Removal ??? 22 Oct 2014 20:10 #651471
  • Zephyrrider
That should be your filter cover oring ? The ones i am referring to would be much smaller - about 25 - 30 mm.I am not familiar with your exact model - just figured they would be similar to mine. Have you got a Manual ?
Mick
Oil Pan Gasket Removal ??? 22 Oct 2014 21:18 #651488
  • kzdcw
  • 77' KZ1000A
I do have a FSM. There is the Filer Cover o-ring that measures 105mm which usually comes with the oil filer. And then there's the oil pan internal o-ring that measures 91mm. I'm not aware of anymore at least associated with the oil pan.
77' KZ1000A
Oil Pan Gasket Removal ??? 22 Oct 2014 22:37 #651499
  • FaultedGeologist
  • FaultedGeologist's Avatar
  • The truly educated never graduate...
  • Thank you received: 7
On mine there are three small O rings around 1cm each if I remember right. I just swapped mine with one from ebay purchase. U can prob search it on ebay and find a pic, but don't forget these O rings as I think the passages channel the oil to different parts of the engine that absolutely need the lube. When u pull the pan, check the underside of the crankcase to see if they stuck up there. U can also wipe out any settled grime that sits in the bottom of the case while pan is off. At work now, else would confirm w pics.
Clint a.k.a. Faulted Geologist
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
NO PHILLIPS HEAD SCREWDRIVERS!!
kzrider.com/forum/10-new-members/603905-new-member-kz750-1984-project#742729
Oil Pan Gasket Removal ??? 22 Oct 2014 23:57 #651501
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
One large o-ring on the kz1000 motors; the 750 is a different engine and has the little o-rings in there
Past; 78 kz1000, 83 kz550
Andrew
  • Page:
  • 1
