650ed wrote: ...When replacing points observe carefully how the little bits and pieces are arranged where the wires attach. Some of those pieces are actually insulators and if you leave any of them out or put them back in the wrong place the points will be grounded and won't work....
This is crucial and very easily checked with your meter. Stick a piece of paper in each set of points to keep them open and check for continuity (ohm setting or beep if your meter has that) between the spring and the backing plate - there should be none, if you see continuity something is installed incorrectly.
The insulating spacers, coil wire, condenser wire and spring should be installed like in the pic below (especially note the position of the insulating spacers) - the coil wire, the condenser wire and the spring side of the points should all have direct contact with each other and none of them should have any contact with the backing plate/ground when the points are open or you will have no spark or a weak spark.
If the coil wire isn't in contact with the spring the primary circuit is constantly interrupted = no spark.
If the coil wire is in contact with the spring and both are in contact with the backing plate or if just the coil wire is in contact with the the backing plate the primary circuit is constantly grounded = no spark.
If the coil wire is in contact with the spring and both are insulated from the backing plate but not in contact with the condenser (or the condenser is defective) the condenser will not do it's job when the points start to open = weak spark.
