Had to wait a week. Weather got cold out. But I ran the bike today (10/11/14) for a little bit. Fired right up as always, idled nice, revved ... and LEAKED. This time from the valve inspection cover gaskets and at the base of the cylinders. WHAT??? I feel like I'm starting to run in a circle. Run bike, spot leaks, check bolts. Run bike, spot NEW leak, check bolts.
I am VERY suspect of two issues now.
1) The O-rings I used for the two rear oil passages on the bike that sit inside the oval area of the head gasket were not the perfect oval shape of the OE gasket. I used Viton O-rings there as i didn't get new OE O-rings with my gaskets. Wondering if I pinched an O-ring and oi l is getting past.
2) I need to take apart and check everything from cylinder O-rings up.
The only area I have yet to see any leak from is the valve cover gasket. And I applied a thin layer of Permatex MotoSeal 1 gray gasket maker.
