  • Page:
  • 1
z1r rotor coming loose 17 Apr 2014 05:06 #629386
  • mrdatsunturbo
  • mrdatsunturbo's Avatar Topic Author
  • mrturbo Norway
  • Thank you received: 2
what can i do with this today the rotor came loose when i tried the starter button ,
The previous owner changed engine so the crank is with aligment key but the rotor is without.
But everytime it is clean, polished, locktite on the bolt and also locktite on crank.
So new gasket everytime and today i pushed the starter before cover was back on and rotor was loose after three times on starter button :angry:
So my tought that this is good enough?? Others that had same problem and fixed it? thanks
z1r rotor coming loose 17 Apr 2014 05:34 #629389
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
can you put on a stator that matches the crank with the key way?
z1r rotor coming loose 17 Apr 2014 06:19 #629396
  • mrdatsunturbo
  • mrturbo Norway
Yes i will try to search one ,i will put up in wanted section.
Thanks Leon
z1r rotor coming loose 17 Apr 2014 07:59 #629404
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1467
You need the earlier rotor and woodruff key.
The bolt on those keyed cranks is only 8mm and can't be tightened enough to hold without the key.
The later keyless cranks went up to 10mm on the rotor bolt to compensate.
I always lightly lap the rotor to the crank with some fine grinding paste for a perfect fit.
Never had one spin yet after doing that.
z1r rotor coming loose 17 Apr 2014 10:29 #629410
  • mrdatsunturbo
  • mrturbo Norway
Thank you very much for info this is new for me that it is not compatible. But i found one on ebay.
So it is on my way. thanks again from Norway
Last edit: by mrdatsunturbo. Reason: spelling
z1r rotor coming loose 05 May 2014 22:04 #631477
  • mrdatsunturbo
  • mrturbo Norway
rotor and woodroof key is on, testdrive is done and everything is perfect.
The starter clutch is also working nicely, because this was binding with the other rotor.
So the bike will be on the road again.Thanks again for helping :laugh:
  • Page:
  • 1
