Cam end plug opinions
Poll: opinions on cam end plugs which one to use (was ended 0000-00-00 00:00:00)
| polished aluminum |
3 | 17.6% |
| black oem style |
8 | 47.1% |
| APE aluminum |
6 | 35.3% |
| Total number of voters: 17 ( GPz550D1, roy-b-boy-b, DuaneBallard, dbc92s10, richard_oxon , undiablo, Street Fighter LTD, aek, ramtough_63, wireman, Powerstroke_fan, dejavoodo41, goodfastncheap, MDawnz1, Garn, Dr. Gamma ) See more See less | |||
| Only registered users can participate to this poll | |||
- ramtough_63
05 May 2013 18:23 #585818
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Cam end plug opinions was created by ramtough_63
getting ready to order cam end plugs just wanted some opiions on what most people prefer too
see and any comments on the aluminum vs the plastic/rubber whats are your thoughts
my cam cover end are semi polished (quick polish job going to have a valve cover chromed)
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Powerstroke_fan
- Thank you received: 90
05 May 2013 18:47 #585824
by Powerstroke_fan
1977 KZ 1000 work in progress
Replied by Powerstroke_fan on topic Cam end plug opinions
I personally have the polished aluminum but id say it all depends on how the motor looks. But either way i would buy aluminum.
- zed1015
- Thank you received: 1980
05 May 2013 19:08 #585828
by zed1015
Replied by zed1015 on topic Cam end plug opinions
Buy Once, Buy aluminium.
You can get black anodised ones if you want them to blend in and look like the original rubber items.
- Dr. Gamma
- Thank you received: 706
05 May 2013 22:08 - 05 May 2013 22:10 #585862
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Cam end plug opinions
I always used the OEM rubber ones installed with the little lip toward the inside of the head.
I never had one leak when installed in that reverse direction.
Plus that little splash of gold inside of them looked real good on the grey of my GunKoted motors!!
Last edit: 05 May 2013 22:10 by Dr. Gamma.
- Dr. Gamma
05 May 2013 22:08 - 05 May 2013 22:15 #585861
by Dr. Gamma
Sorry, computer F/U. Hit SUBMIT key four times, sorry again!!
Last edit: 05 May 2013 22:15 by Dr. Gamma.
- Dr. Gamma
05 May 2013 22:08 - 05 May 2013 22:13 #585860
by Dr. Gamma
Last edit: 05 May 2013 22:13 by Dr. Gamma.
- Dr. Gamma
05 May 2013 22:08 - 05 May 2013 22:13 #585859
by Dr. Gamma
Sorry computer F/U!!!!
- Thank you received: 796
06 May 2013 11:30 #585974
by 531blackbanshee
Replied by 531blackbanshee on topic Cam end plug opinions
i'm in the once and done aluminum camp.
- Thank you received: 2302
06 May 2013 11:53 #585978
by Street Fighter LTD
Replied by Street Fighter LTD on topic Cam end plug opinions
Bought once and installed 35 years ago . Never any problems. Especially with high power motors or boosted motors with higher crankcase pressures.
GO ALUMINUM. Cheap investment
- Jeff.Saunders
- Thank you received: 149
06 May 2013 12:13 #585980
by Jeff.Saunders
Replied by Jeff.Saunders on topic Cam end plug opinions
The billet aluminum cam-end plugs can work well. However, they can be a problem on a few heads - most noticeably the earlier Z1 heads. Ideally the line boring for the cams would be a perfect intersection of the head and cam caps - but what you find is variations up and down on the machining - to the tune of over 20 thou on some heads. This means the cam-end plugs can sit high or low on these heads. If they sit high, the only thing you can do is remove a little metal from the upper surface of the billet aluminum. If they sit low, you have to put a thin bead of gasket goo to help seal them.
When I first bought my 1973 turbocharged z1, the bike came with RC Engineering billet cam-end plugs - and they sat high and leaked oil from that area. At first I thought they were just poorly made, but when they were installed in a kz1000 head, they fit perfectly. I checked 10+ heads in my garage, and was very surprised on the depth difference from head to head.
- Garn
- Thank you received: 13
06 May 2013 19:05 - 06 May 2013 19:11 #586032
by Garn
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Replied by Garn on topic Cam end plug opinions
I like the alloy plugs (anodized black not blue).
There has always been two schools of thought, as regards to the sealing of these alloy cam-end plugs. One is to seal the circular part with part of an appropriate sized round section of an O-ring. The other, is to fill the vee groove with a sealing compound.
RegardZ.
RegardZ.
Sydney Australia
Last edit: 06 May 2013 19:11 by Garn.
- turboking
- Thank you received: 106
06 May 2013 20:12 #586035
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic Cam end plug opinions
I've turned oem rubber cam plugs with the lip inside the head and used the billet aluminum plugs......both work :huh: I think the inverted oem plugs give a road race look to the engine........ :dry:
1985 GS 1150E
1983 GS 1100E
