oil in my stator cover
  • kenfowler123
  • kenfowler123's Avatar Topic Author
18 Apr 2013 11:33
#582953
I was replacing gaskets on a 1982 kz 1100 a shaft and there was oil in my stator cover. Is this normal or is this a problem? I appreciate any input.
1982 KAWASAKI KZ 1100 A SHAFT
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
Re: oil in my stator cover
18 Apr 2013 11:50
#582954
Its normal in my 78 1000
  • martin_csr
  • martin_csr's Avatar
18 Apr 2013 13:17
#582958
Some models have oil behind the stator cover, because they don't have an oil seal on that end of the crankshaft (pretty sure). There may be a weep hole for the oil to drain back into the oil pan?
For comparison, the 81 650 is dry - the oil seals for both ends of the crankshaft are listed in the crankshaft diagram. The crankshaft diagram for the 1100-A2 doesn't show any seals, but the engine covers diagram shows one on the ignition side.
  • zed1015
  • zed1015's Avatar
18 Apr 2013 14:51
#582963
kenfowler123 wrote: I was replacing gaskets on a 1982 kz 1100 a shaft and there was oil in my stator cover. Is this normal or is this a problem? I appreciate any input.
It is normal on all 900 thru to 1100 KZ's so no need to worry.
  • MFolks
  • MFolks's Avatar
18 Apr 2013 15:41
#582967
The oil is lubrication, & provides cooling for the stator windings and the starting clutch behind the alternator rotor. That's why it's important to use the correct engine oil, not some oil designed for a car, as "Oil is Oil" does not apply.
JASO OIL SPECS:
Find an oil that shows the JASO-MA rating on the bottle; there are plenty of them available both dino and synthetic.
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engines from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers."
These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not.
That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
Using oils that are not designated as meeting the JASO-MA standard may be destructive to KZ clutches. Here's a link that may be helpful:
www.oilspecifications.org/jaso.php
  • kenfowler123
18 Apr 2013 16:46
#582971
Thanks too all, now I can sleep.
  • Kitten Tooth
  • Kitten Tooth's Avatar
18 Apr 2013 22:00
#583013
I know the feeling. I made the mistake of putting my bike on its sidestand with the AC generator cover off and all my motor oil poured out. I crapped my pants.. until i found out it was normal.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
The following user(s) said Thank You: kenfowler123
18 Apr 2013 23:00
#583021
Good Fortune! :)
