hugo wrote:
When the starter motor rotates the starter clutch, it grabs against an engine that IS NOT TURNING. As soon as the engine catches, turning on its own power, it spins faster than starter clutch, so there is nothing to grab. It is not centrifugal forces that disengage, is relative speed. At this point, if the starting motor is kept engaged, it will keep turning the starter clutch, but secondary shaft(750-Four)is moving faster, so rollers don't catch.
I'm sorry, but that is not correct. When you push the start button, the starter motor spins and drives an idler gear sitting in the top of the crankcase, the idler gear then drives the starter clutch gear sitting on a needle roller bearing on the secondary shaft.
The rollers in the starter clutch housing grabs on to the starter clutch gear and the housing rotates with the gear - this will make the crank turn as it is tied to the starter clutch housing through the primary chain.
Once the engine starts, the process is reversed. The pistons drive the crank, the crank drives the starter clutch housing through the primary chain and the starter clutch housing drives the secondary shaft - the starter clutch housing is sitting on splines on the secondary shaft and will rotate at excactly the same speed as the secondary shaft, this is what cause the rollers to be forced back, they do indeed release by centrifugal force - motion is then transferred through the secondary shaft gear to the clutch basket, transmission and so on.
However, once you release the start button, the starter, idler gear and starter clutch gear stop spinning, when the engine is running they are standing still - the purpose of the oneway is partly to prevent spinning the gears and starter motor as the rollers re-engage the starter clutch gear when you shut the engine down, partly to allow you to use the kickstart (if so equipped).
The grinding sound you hear once in a while is the rollers failing to grab on to and slipping on the starter clutch gear.
