Vance and Hines exhaust future
- PLUMMEN
Re: Vance and Hines exhaust future
11 Dec 2008 11:06
Patton wrote:
i had a black one on my 82 gs1100e one of these days ill find one for a kaw,untill then im sticking with turbos!:laugh:
correction sir,that is the most beautifull exhuast ever built for a big bore bike!EricHa wrote:trianglelaguna wrote:...sometimes(twice) i see em on e-bay but i've spent all mama will allow on a header for a while...
Yep, I let one go on Ebay a few months back, I bidded it up to $210, but didn't go high enough. Haven't seen one since. I like the fact that the megaphone doesn't flare, it's the same diameter all the way back. Yoshimura USA will import a vintage Z1 header from Yoshimura Japan, but they're $1000 and don't have that great upswept angle of the above pipe.
Thanks for posting the photo.
That's the Yoshimura exhaust I enjoyed running for several years, finished in chrome. Imo, one of the most beautiful exhaust systems ever made for the large fours. And excellent performance (especially without the short easily removed baffle). Deep throaty sound without the baffle, not painfully loud. But not so great sounding with baffle installed, imo.
Am thinking oil filter change required removing the headers, which was the deal killer for me (especially when cross-country touring). But have always regretted not having had sense enough to hang onto it.
Good Luck!
- timebomb33
11 Dec 2008 12:46
that japanese site has the coolest stuff i found all kinds of goodies frame brace kits, motor mount kits ,1000r fairings and windshields every thing a guy could want for christmas.
I THINK MY POWERBAND BROKE
- Exitpupil
11 Dec 2008 13:14
Two things:
Ability to change oil filter with pipe in place.
Better ground clearance. Many guys are lowering their bikes and even an inch is a big difference in ground clearance.
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- EricHa
12 Dec 2008 04:55
Yeah, the oil filter access is important. If you're going to lower your bike very much, you have to at least consider a sidewinder/pro pipe.
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
1975 Honda CB550K
12 Dec 2008 05:33 - 12 Dec 2008 05:34
EricHa wrote:
On the Z1 with the Yoshi pipes, lowering the front end by raising the fork tubes an inch higher in the clamps did not create much of a clearance issue, either ground or wheel/fender with hard front braking.
Good Luck!
... If you're going to lower your bike very much, you have to at least consider a sidewinder/pro pipe.
Good Luck!
Last edit: 12 Dec 2008 05:34 by Patton.
- wiredgeorge
12 Dec 2008 06:54
Jeff, IF you have pipes made, keep in mind that MANY owners originally had 4 into 2 pipes. The only sources for 4 into 2 have turn out mufflers which I doubt most folks enjoy looking at. I sure don't. If you get pipes made, a 4 into 2 with megaphone mufflers would really be nice... similar to the OEM stuff on the later KZ1000s in chrome but I bet BLACK would also be a good seller. If you had pipes made up, I bet a 4 into 4 replica pipe would also sell if you could get the price within reason.
13 Dec 2008 07:07
This place has some interesting possibilites -
www.klasmo-bikes.de/land.php?auswahl=mod...land1=USA&kunden_id=
I am particularly interested in the Cobra Duplex #710709Z, though I wonder how much shipping will be. They sell several systems that I think are not available in the US by other means, which would give them, imo, extra bling points for exclusivity.
By the way, whoever did ther English translation needs further study, so be warned - you will have to use some creative interp. of your own.
- Jeff.Saunders
13 Dec 2008 07:11
The 4-2 pipes would be a strong consideration.
There are some 4-2 pipes avaialble today, but they are either very expense (like the ZeCross system we sell), or too crappy (like MAC).
The key challenge is getting them made at a price point we all can live with. Most of the manufacturers require runs of 50 or more pipes at a time.
- Jeff.Saunders
13 Dec 2008 07:19
TexasKZ wrote:
The problem with importing pipes from overseas is you can run into issues with US Customs and DOT requirements. If you import a pipe for a bike later than 1977, the pipes MUST adhere to DOT/EPA standards. If US Customs determines a pipe does not conform, it may get sent back or destroyed. Because of this issue, we've avoided importing a couple of the pipes from Japan.
- Mcdroid
- Gone Kwackers
13 Dec 2008 07:40
Jeff.Saunders wrote:
So, in theory, if you import a pipe for a Z1B and it not so coincidently also fits 1977-80 KZ1000B models, the pipe might slip by US Customs?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- trianglelaguna
13 Dec 2008 07:40
just tell em they help motorcycles here get down to 11 miles to the gallon and the u.s will import em for us..in fact they will give us employee discount programsJeff.Saunders wrote:
TexasKZ wrote:This place has some interesting possibilites -
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Jeff.Saunders
13 Dec 2008 09:02 - 13 Dec 2008 09:03
Mcdroid wrote:
If the pipe is imported as for a Z1, KZ900 or 1977 KZ1000, you'd be OK. Import it for a 1973-1980 Kawasaki 900/1000 and you won't be.
With any import, your shipper should be including a manifest with all this information on. With individuals importing today, US Customs doesn't force you file detailed import documentation unless you go over $2,000 value - although a number of shipping companies do require a detailed contents description regardless. However, the package may still be inspected and subjected to US Customs import laws.
Historically, packages through the Post Office have not required so much detail - however, many of the laws today around the Postal Services import/export processes will be changing to level the playing field for all shipping entities regardless of whether they are government based or privately owned.
Last edit: 13 Dec 2008 09:03 by Jeff.Saunders.
