DoubleDub wrote:
The clymer claims there are 17 bolts. I can only find 16. Can anyone out there verify if there are 17 bolts on a '76 900?
Is there something I can leverage to take the thing off without damaging any of the precious aluminium one I verify I have all the bolts out? The engine is still in the frame - I had a brain fart and lost a bolt down the crankcase.
I would try taking a spakle knife and sharpening the front edge and try to tap it in slowly at the edges that are exposed to insertion. Just work your way around.
same tool will help scrape the gasket off.
And if you gouge the aluminum lip getting it off.... that's what the hi-temp black RTV sealer is for. You aren't the first one.
