  • Page:
  • 1
29mm & 13mm valve shims available again - finally 21 May 2015 11:51 #673006
  • Jeff.Saunders
  • Jeff.Saunders's Avatar Topic Author
  • Vendor
  • Thank you received: 175
Finally, we should have some of the 13mm & 29mm valve shim back in stock next week. This has been a horrible wait.
For those of you not familiar with the issue. K&L (the importer) ran into some quality issues with valve shims in the middle of last year. A few shims made it through manufacturing that were out of spec. I've seen a few different issues including some that were not perfectly round. Thicknesses varied more than they should. The +/- on the thickness was over a full shim size on some of the shims. There were a couple of instances where the surface on shims showed some pock marks that might have been a related issue.
K&L switched manufacturer and initially expected to receive new shims early this year, that's slipped and slipped.... well finally K&L received them in yesterday. They are going through a QC process to ensure they are all good, then they will pack for shipment. We anticipate receiving them late next week. Their initial shipment is only half of what they ordered, so it's possible the stock will evaporate quickly. We'll start taking orders on these again now we know they are truly available...
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
29mm & 13mm valve shims available again - finally 21 May 2015 19:28 #673071
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
Good to know as I will be needing shims when I do cams soon.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
The following user(s) said Thank You: Randombeat
29mm & 13mm valve shims available again - finally 22 May 2015 02:27 #673105
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 360
Agree good news!
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
  • Page:
  • 1
