I found this 1986 GPZ550 for sale and couldn’t pass it up. It compliments my 1980 KZ550 the first year of the 550 motor since the 1986 is the final year of the 550. Plus it was in excellent condition and only had 10,300 km. The PO kept it garage stored for the past 8 years and only started it up every once in a while but didn’t really ride it, apparently the same with the previous PO. The bike started, motor ran great, everything appeared to work. I am calling it a renewal since I don't have much restoration to do.
Attachment not found
I plan on changing oil, oil filter, air filter, replace brake fluid, fork oil
Lubricate swing arm pivot, uni-track linkage, steering stem, cables, speedometer gear, wheel bearings
I will check the valve clearances
Pulled the spark plugs and they appear good but cheap to replace
The chain looks ok and is within tolerance 317mm and sprockets look ok
The headlight glass has a chip in it and needs replacement
The right signal lights were not working and I traced the problem to where the wire split at the headstock to go to the indicator and the signal light
The Bridgestone tires F-100/90-18 R-120/80-18 are old and have cracks and will be replaced probably Bridgestone or Pirelli same size
KZ Forum Members Advice Needed
Due to the age of the bike the manual says replace the brake hoses, anti-dive brake plunger assembly, master caliper cup and dust seal, caliper piston seal and dust seal. I know the bike is 30 years old but the forks and brake calipers look good and work great and to replace all this will cost $250 so I am thinking of leaving them as is. Even the disc brake pads appear to still have lots of material left and at $35 a set I am thinking of not replacing them until the wear requires it. I would appreciate any advice from members on these items.
Thanks
