Making a key by the code number. 04 Dec 2010 17:01 #415346
  • Tony
  • Tony's Avatar
  • Thank you received: 13
This is a great thread and lost keys are an on going problem. I don't know about everyone else, but I think this thread should be stickied. Since I've got the little button that allows me to make this a sticky, I'm going to go ahead and do just that. :)
Making a key by the code number. 20 Mar 2011 13:55 #439170
  • gmannz1
  • gmannz1's Avatar
  • Thank you received: 0
I'm looking for a key for a 1980 KZ750 twin. I found the number on the ignition and it matches the seat lock. I bought a key with the same number, but its labeled GPz, it fits the lock (correct blank), but doesn't open the lock. I talked to a local locksmith who had the cutting code for 1984 and later for my key code. He thought they were probably the same, but I'm not so sure. Has anybody run into issues where the same code number has been used pre-1984 and post-1984, but the keys are different? Or can you help me find a 1980 version of key code Z5365.
Thanks
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
Making a key by the code number. 21 Mar 2011 23:55 #439600
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
  • Thank you received: 75
Well, I had a key cut at the locksmith from the number off of the ignition. I don't know if that helps at all but hey if a key is what you need then this is what you should do.
79 LTD B3
Making a key by the code number. 01 Apr 2011 02:06 #441859
  • purls
  • purls's Avatar
This is great info. Thanks.
1983 KZ750 Spectre
1978 KZ650B2A
Making a key by the code number. 01 Apr 2011 10:55 #441911
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
  • Thank you received: 29
If you have the earlier (4 cut) key, check with an older Kawi dealership. Ma Kaw offered pre-cut keys by the lock number back in the 70's, and if they haven't round-filled them some of the older dealerships still might have some. B)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
Making a key by the code number. 01 Apr 2011 17:20 #441982
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
  • Thank you received: 36
There are a few retailers out there with OEM pre-cut keys in stock. I paid 15 bucks for my cherry black plastic OEM key. Just match the code and you're set.
Do a Google search for Kawasaki pre-cut keys. I'll send out a few links at a later point when I'm not at work.
2000 ZRX 1100
1976 KZ 900- Daily Driver
Making a key by the code number. 02 Apr 2011 04:26 #442117
  • mtbspeedfreak
Here you go: www.johnnysvintagemotorcycle.com/
Also, give eBay a shot too. Like I said, I just got a "brand new" OEM key. Black plastic with the Kawasaki shield on it and everything. Cherry. Very happy. The $15 was well spent in my book.
2000 ZRX 1100
Making a key by the code number. 02 Apr 2011 20:31 #442227
  • rstnick
  • rstnick's Avatar Topic Author
  • Thank you received: 376
gmannz1 wrote: I'm looking for a key for a 1980 KZ750 twin. I found the number on the ignition and it matches the seat lock. I bought a key with the same number, but its labeled GPz, it fits the lock (correct blank), but doesn't open the lock. I talked to a local locksmith who had the cutting code for 1984 and later for my key code. He thought they were probably the same, but I'm not so sure. Has anybody run into issues where the same code number has been used pre-1984 and post-1984, but the keys are different? Or can you help me find a 1980 version of key code Z5365.
Thanks
The Z**** series does have two sets of codes.
IIRC they're labeled Z****(Older) and Z****(Newer) in the program.
Not sure off hand what year the change over was.
Can you take a picture of your key and post it so I can read the bittings and determine if it matches the Old or New series?
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: Mullineaux
Making a key by the code number. 16 May 2011 13:56 #451452
  • KZShafted
  • KZShafted's Avatar
Thanks for the post. I broke my only key in the tank lock to my 95 Police1000 yesterday and this info was very useful. A local locksmith was able to help make a new one and it was a whopping fifteen bucks. As luck would have it I was able to get the broken piece out without causing damage.
1980 KZ1000 Shaft
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
Making a key by the code number. 17 Jun 2011 19:04 #457842
  • Kawasaki_Mike
  • Kawasaki_Mike's Avatar
  • 1980 Kawasaki 750 LTD
I sent a message to the OP (rstnick) regarding getting some keys made up for my 1980 Kawasaki 750 LTD. Does anyone know if he is still around and can still do this? If not, can someone else point me in the right direction? Thanks all.
Making a key by the code number. 06 Jul 2011 13:29 #461315
  • ravenz07
  • ravenz07's Avatar
I would also like to know the answer to the same question. I have the same bike and have the key code. Anyone here can do it?
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
Making a key by the code number. 21 Aug 2011 00:22 #470548
  • rstnick
Send me an email at This email address is being protected from spambots. You need JavaScript enabled to view it. as I don't see posts here often enough.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: sig, Kawasakik1e
