Difference between KZ1000 and a MKII
  • larrycavan
  • larrycavan's Avatar
Re: Difference between KZ1000 and a MKII
13 Jun 2010 10:26
#375446
Here's a 77 motor. Notice less ribs on the front of the cases.
With the age of these motors and mods being so commonly done, it's never safe to assume anything. Cases are easy to spot the differences but what's inside you can't be sure of unless you count either the crank teet [difficult] or the camsprocket teet[easy].
I have MKII, KZ and J cases all sitting in the attic at the shop. I also have KZ, J and late model GPz11 heads. I'm going to get a bunch more photos and post them on my site so it's easier for guys to figure out what they have.
  • larrycavan
13 Jun 2010 10:29 - 13 Jun 2010 10:49
#375447
MKII rear view. Trans cover, bottom corner & the rib behind the oil fill tower extends on down to the top of the engine case. KZ cases, the rib on the oil tower is shorter it stops before the top of the cases.
Last edit: 13 Jun 2010 10:49 by larrycavan.
  • larrycavan
13 Jun 2010 10:41
#375448
Trans cover & case shape differences. Notice the lower right corner of the trans cover. Curved on MKII.
Also if you have the trans cover off the motor, the MKII cases have 2 boss locations where the shift shaft can be installed. One for Shaft Drive, the other for Chain Drive.
  • porchev914
  • porchev914's Avatar
13 Jun 2010 10:42
#375449
OK, so that we're all clear, this reinforcing rib:
Helps identify a MKII case?
FRANKEN Z!
  • larrycavan
13 Jun 2010 10:47
#375451
But see how yours doesn't go all the way down on the cases. It's shorter than the MKII rib.
  • porchev914
13 Jun 2010 10:47
#375452
And this curve here Larry?
FRANKEN Z!
  • porchev914
13 Jun 2010 10:49
#375454
Thank you for the clarification for those of us less experienced in these things Larry
FRANKEN Z!
  • larrycavan
13 Jun 2010 10:55
#375456
Here's the 2 rib differences on the oil fill tower.
  • larrycavan
13 Jun 2010 11:01
#375458
BTW....You're engine cases are looking pretty darn good! :)
  • porchev914
13 Jun 2010 11:04
#375460
OK Larry, I finally understand what I'm looking at :blush: Thank you for noticing, my cases look almost as good as yours! You'll get a better look once I send you my head B)
FRANKEN Z!
  • Lazyman06
  • Lazyman06's Avatar Topic Author
13 Jun 2010 17:43
#375536
sorry for the late reply guys. the engine VIN is KZT00AE-091614 the frame VIN is KZT00A-042004. The bike is rough but it runs.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
13 Jun 2010 18:54
#375555
Sorry . i dont get this 1? this is a kz. but the mk11 looks like it has this curve as well?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
