RPM vs. Speed. What do you get.
  • otakar
  • otakar's Avatar Topic Author
14 Nov 2009 12:26 - 14 Nov 2009 16:13
#333646
I just went on a cruise and decided to pay a bit closer attention to the revs at speed. this is what my GPz1150 is getting. Mind you the gearing is not stock and will change again in the spring for a higher top end.
3K = 49Mph
4K = 65Mph
5K = 81Mph
This equals 16Mph per 1K in RPM. this test was done with a GPS along with the spedo. The spedo turns out to be quite accurate.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 14 Nov 2009 16:13 by otakar.
  • ccvt98
  • ccvt98's Avatar
Re: RPM vs. Speed. What do you get.
14 Nov 2009 14:54
#333665
i have aa 80 kz750 ltd mine is:
3k = 40mph
4k = 50 mph
5k = 61mph
6k = 72mph
my stock gearing is 13/32
but according to www.gearingcommander.com/
website it should be different, so ,i think i may have a 12 tooth in front.
1980 KZ750H1 LTD *restored*Feb '09
1982 KZ1100A2 Shaft *in process of resto*
1982 KZ750 Almost Completed
2001 Honda XR100 "son's"
2010 Kaw Z1000
  • otakar
14 Nov 2009 16:47
#333694
My final gear ratio at the moment is 38/15 (1:2.53) and stock was 41/15 (1:2.73) I will be converting to a 530 from the original 630 chain and going with a ratio of 17/40 (1:2.35)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
16 Nov 2009 07:45
#334063
With stock sprockets ( 35/15 ) I see 80 MPH indicated at 5K RPM. This on my KZ900.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KYKZ1100
  • KYKZ1100's Avatar
19 Nov 2009 00:11
#334563
I thought my KZ1100 shaft was turning over too fast on the highway but now I don't feel so bad. Using the GPS it goes:
3k = 45 mph
4k = 60 mph
5k = 75 mph
The Cycle World road test in 1981 showed 3640 rpm at 60 mph and the Motorcyclist test showed 3569 at 60. I don't know why mine is turning faster unless it's the tires (Kenda Challengers) on mine. Is there anything else that could affect it?
1981 KZ1100A1 Shaft
2007 BMW R1200R
  • otakar
19 Nov 2009 04:04
#334570
Only the front tire can affect it. I would check the variation difference between the GPS and your speedometer. I fiddled with mine until I got it with in 2% on the Odometer and right on the money on the Speedometer. This is all, using the GPS for calibration.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Bluemeanie
  • Bluemeanie's Avatar
19 Nov 2009 05:58 - 19 Nov 2009 05:58
#334585
My spedo is off (found out with my GPS). How did you "fiddle" with it? What adjustments are you talking about? :blink:
Last edit: 19 Nov 2009 05:58 by Bluemeanie.
  • otakar
19 Nov 2009 06:14 - 19 Nov 2009 06:16
#334587
The simplest way is by picking the correct size front tire. Otherwise Kawasaki makes different size/pitch gears for the spedo drive unit. I am not sure how custom your bike is, and if you have a stock size front wheel or tire. I did it by disassembling the spedo and changing some gears and the return spring tension, but that is a He** of a lot of work. Still the best way is to put a larger os smaller front tire on the bike dependent on which way you have to go.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Nov 2009 06:16 by otakar.
  • hoghaterkaw
  • hoghaterkaw's Avatar
19 Nov 2009 08:05
#334609
i would like to add that the rolling diameter of the rear tire does affect top speed. a larger rolling diameter tire will travel a greater distance than a smaller rolling diameter tire at the same RPM. so the larger rear tire will give a higher MPH.
  • otakar
19 Nov 2009 08:41
#334615
Yes rear wheel size and sprocket size will affect top speed, provided that you have the torque to turn it. It however will not affect the indicated speedometer speed.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Old Man Rock
  • Old Man Rock's Avatar
19 Nov 2009 10:02
#334623
My build... Modified KZ900 15/37 sprockets... 17" tires.
65mph @ 4500rpms...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
19 Nov 2009 10:56
#334629
My '82 KZ650 CSR had stock gearing of (33/13)= 2.54, with 630 chain.
Using a GPS for indicated speed:
60 MPH - 4,950 RPM
I changed the front sprocket to a 14 tooth. (33/14) = 2.36 This yielded:
60 MPH - 4,600.
Even with the 650, it has plenty of torque to run at most any speed. A larger engine, such as a 1000 could probably handle a 2.2 ratio if highway cruising is the goal.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
