76 KZ900 06 Mar 2023 16:07 #881185
  • mvent
  • mvent's Avatar Topic Author
  • Thank you received: 16
Picked up this one owner KZ900 today, 9800 miles parked in 2003. Will start picking away at it soon I planned to clean carbs and put battery in to check mechanical and electrical out and go from there.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: by Street Fighter LTD.
76 KZ900 06 Mar 2023 17:20 #881186
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1884
Very solid. Just FYI, it has Z1A-B carbs.
The following user(s) said Thank You: mvent
76 KZ900 06 Mar 2023 17:45 #881189
  • mvent
Mikaw thanks for that, would have been a problem when ordering carb parts.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
76 KZ900 06 Mar 2023 17:52 #881190
  • Mikaw
  • Mikaw's Avatar
Pull the plugs and put marvel mystery oil in them while you work on other stuff. Open the carbs and post pictures. Don’t butcher them up by trying to install “Kits” I’d be willing to bet, unless they are completely trashed, that you can reuse all the brass. Nessism should be able to help you with ORings, buy good gaskets. No rubber evilbay stuff. Go to Jets r Us, Nichecycle or Sudco.
Last edit: by Mikaw.
76 KZ900 07 Mar 2023 03:14 #881194
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1918
Hard to believe there are still gems like this sitting in sheds waiting to be rescued, looks completely unmolested (except by critters !!)
The following user(s) said Thank You: MLMG
76 KZ900 07 Mar 2023 04:15 #881195
  • Mikaw
  • Mikaw's Avatar
I’m jealous. I’d love to find a jem like this. I’d do a mechanical restoration and drive it as is.
76 KZ900 07 Mar 2023 07:31 #881197
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
You really have something here.
How is the inside of the tank I’m afraid to ask?
76 KZ900 07 Mar 2023 09:16 #881201
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 386
Agree with all said.  You have found yourself an interesting machine.  I look forward to seeing more as you get to know it better.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
76 KZ900 07 Mar 2023 16:18 #881222
  • mvent
Tank that's on the bike I don't believe is original to bike, it appears to have been coated and looks real good. Also have an original paint tank which was probably the original, coating inside is flaking off there are no soft spots at all and paint is pretty good. Under the seat was the tool kit, owners manual with warranty kard ( spelled with a k )
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
76 KZ900 08 Mar 2023 08:13 #881247
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 261
Nice find indeed, I find it odd that it has early VM28's on it with it showing such low miles. Would be interesting to see the engine ID#.
76 KZ900 08 Mar 2023 11:45 #881252
  • mvent
Here it is
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
76 KZ900 09 Mar 2023 16:38 #881319
  • mvent
Removed carbs to clean, must have been drained of fuel before parking, jets look good but inlet throats on a couple of carbs had crud.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
