  • Page:
  • 1
  • 2
Finally picked up the 1972 H2 Barn Find 24 Sep 2022 11:25 #874442
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1816
It's "gold" in the garage sweetheart
Finally picked up the 1972 H2 Barn Find 26 Sep 2022 18:14 #874648
  • 577nitro
  • 577nitro's Avatar Topic Author
  • Thank you received: 56
Parts list is building up fast...just dropped some bills on sorting the seat and grommets...lots of grommets.   The thing did not come with a brake, so I'm going back and forth on whether to go dual disk stock, single disk stock or a set of period correct AP's dual disk.   EBC makes a sweet upgraded disk that is full floating and drilled.  The stock brakes are just about worthless even when they are working perfectly.  But..stock brings the most $$$...if I were to sell it.  UGH....Oh, and to go full stock is more than the upgraded AP setup.  Used clapped out brakes are stupid expensive.for stock.   There are aftermarket reproductions, but I figure if your going stock, use the real deal parts.
577nitro-
Finally picked up the 1972 H2 Barn Find 26 Sep 2022 20:10 #874656
  • cb900f
  • cb900f's Avatar
  • Thank you received: 30
'... ran when purchased'
Finally picked up the 1972 H2 Barn Find 01 Nov 2022 15:49 #876284
  • 577nitro
Found a place that sells oversized rims for the H2, so I'm going to get a set of Alu.,  front 18" x 2.75" and rear at 18" x 3.5".  I'll be able to put a 110 on the front and a 140 on the rear.
I'll feel safer with a little meat to the ground.   Pretty much decided to go with an AP twin brake setup on the front with stock diameter EBC full floating rotors.   To buy a used stock twin disk setup is MORE than the AP upgrade.
577nitro
  • Page:
  • 1
  • 2
