1973 Z1 rebuild 14 Jun 2022 02:38 #868750
  • blackozvet
  • blackozvet's Avatar Topic Author
  • Thank you received: 79
In Australia the most popular term for red heads is "Ranga"
1973 Z1 900 Kawasaki
1973 Z1 rebuild 14 Jun 2022 02:55 #868751
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
Blackozvet, A little off topic but I just saw a report on Yellow Crazy Ants down your way. Are they really that bad?
1973 Z1 rebuild 14 Jun 2022 02:58 #868752
  • blackozvet
update - been away for holiday weekend but slowly making headway in stripping it down.
had to buy a new pair of internal circlip pliers to get that circlip out of the front hub.
the box of bits to be de-chromed is now 2 boxes !  And still got more to go.
1973 Z1 rebuild 14 Jun 2022 03:20 #868753
  • blackozvet
I didnt realise they were becoming a big problem,
they are up in the northern part of Australia - Northern Territory, Queensland, where its tropical.  I live down south.
they will probably end up being like the cane toads, a pain in the butt they have to spend millions trying to control.
The following user(s) said Thank You: blipco
1973 Z1 rebuild 14 Jun 2022 03:53 #868754
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
You’re project looks great. Just lubed my chain. Off on holiday. Cheers.
1973 Z1 rebuild 14 Jun 2022 22:27 #868817
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
It was a 140/70 - whatever that works out to, the tyre is gone now and I cant remember exactly what it measures to.
The insides of the swingarm are pressed so that it can run a wider tyre.
I run a 140/70 with a 3.5" rim on my Z1b.  No need to alter the swingarm or brake stay.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
1973 Z1 rebuild 16 Jun 2022 01:53 #868879
  • blackozvet
The other reason for the pressed swingarm is because of the low tyre pressure being used for drag racing, it tends to squish a fair bit.
1973 Z1 rebuild 16 Jun 2022 02:16 #868880
  • blackozvet
I had my first oopsie moment, undoing a tight bolt and it twisted the bike around coming off the stand under the sump (or oil pan as Americans call it)  and then fell sideways off the rear main stand.
I reached out and grabbed the back of the frame and managed to stop it from coming off the work bench, then I realised that the dynamo cover was off so oil was pouring out everywhere.
Luckily the Mrs heard the commotion and came out and gave me a hand to straighten it all up and mop up the oil.
Anyway a couple of things have arrived, the stainless steel spoke sets and a starter motor that I found on ebay that came with the cover and wire.
1973 Z1 rebuild 16 Jun 2022 06:47 #868890
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
"I had my first oopsie moment, undoing a tight bolt and it twisted the bike around coming off the stand under the sump (or oil pan as Americans call it)  and then fell sideways off the rear main stand.
I reached out and grabbed the back of the frame and managed to stop it from coming off the work bench, then I realised that the dynamo cover was off so oil was pouring out everywhere".
You want one of these
1973 Z1 rebuild 16 Jun 2022 07:14 #868895
  • blackozvet
That looks a bit fancy Wookie, I think I will just modify my big blocks of wood to hold the chassis.
1973 Z1 rebuild 19 Jun 2022 02:44 #869036
  • blackozvet
Finally stripped all the parts and wiring looms off the frame, then stripped all the parts down to go to be de-chromed.
The engine is only sitting in the frame all unbolted ready to come out.
Last edit: by Street Fighter LTD.
1973 Z1 rebuild 19 Jun 2022 03:06 #869037
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Making great progress
