First KZ project…. 1980 KZ1000 10 Nov 2016 15:21 #747728
  • JOE MKII
  • JOE MKII's Avatar Topic Author
  • Thank you received: 25
I have been reading through a lot of the project threads here…Really good stuff and some fantastic projects!
I just started a KZ1000 project myself, first KZ I have ever worked on.
It will be relatively boring. One of the tranny bearings was toast so I have got the engine out and will spit the cases redo the trans and rebuild the carbs , tune up, clean up and I hope to be riding it sometime next summer!
I received two motorcycles when my good friend and cousin passed away a few years back . This KZ and a custom H2 750. I finished the H2 although it will be an ongoing work, and now I am on to the KZ.
This one will be 99% stock and will hopefully live a mundane street life for years to come.
A lot of GREAT info on the site, I have already learned much!!
Anyone with experience with Robinson Transmissions ??
I may send this one out to be looked over and rebuilt by them.
And I have to say Im getting old almost killed myself getting this engine out AND I had help….Age, the great equalizer :dry:
Here are some random pics;
I believe its called "Oppositional Defiance Disorder"
First KZ project…. 1980 KZ1000 10 Nov 2016 16:58 #747733
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2613
You can split the cases without removing the top end. Just be sure you get ALL the #6 bolts and the few crank bolts you can get to.
Nice bike. B)
First KZ project…. 1980 KZ1000 11 Nov 2016 03:55 #747741
  • JOE MKII
Hoping the cases will be split by the end of the weekend so I can get a better assessment of all the damage, which seems very light at tho point.
Question
Block off plates for the smog plumbing, good, bad, I assume theres no problem deleting the smog stuff if I want??
First KZ project…. 1980 KZ1000 11 Nov 2016 04:52 #747743
  • rrsmsw9999
  • rrsmsw9999's Avatar
  • Thank you received: 67
That's a beaut!
I have a lot of parts from 80E2 shafty that would fit that bike. The front end is cashed, but a full refreshed MKII motor, brakes etc are available. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
First KZ project…. 1980 KZ1000 11 Nov 2016 05:03 #747744
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2673
There are various methods to get rid of the air injection system. Done right and there is no ill effect to the bike. When I did my 750 I threaded and plugged off the ports in the head, and I bought a Turbo 750 valve cover which doesn't have the reed valves. I'm not sure what the cover options are for the big KZ's though.
Good luck and have fun with your project. Oh, and thanks in advance for the photos.
First KZ project…. 1980 KZ1000 11 Nov 2016 05:14 #747746
  • JOE MKII
At this point I am really hoping to just do the tranny. The bike is in near mint condition cosmetically, so with nay luck just a good refresh of all the fluids, tune up, and clean up and all will be good, but one never knows.
I can get block off plates easy enough so thats what I am going to do.
First KZ project…. 1980 KZ1000 11 Nov 2016 05:51 #747749
  • dvnsta
  • dvnsta's Avatar
  • Thank you received: 3
Found block off plates on ebay they were pretty reasonanle stripped and buffed they look as nice as some of the more expensive finished plates ive found from other sources on the internet.
1982 KZ 750 LTD H3 stock except with custom seat skin and kawasaki period backrest.
Kawasaki 1989 eliminator 250 b3
Last edit: by dvnsta. Reason: Miss spelling
First KZ project…. 1980 KZ1000 11 Nov 2016 08:17 #747758
  • westmiltonfab
  • westmiltonfab's Avatar
  • Thank you received: 23
Sweeeeeet!!!!!
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
First KZ project…. 1980 KZ1000 11 Nov 2016 08:25 #747760
  • stokes
  • stokes's Avatar
  • Thank you received: 8
Do you have the center stand?
rrsmsw9999 wrote: That's a beaut!
1980 KZ1000B Ltd
First KZ project…. 1980 KZ1000 11 Nov 2016 21:57 #747796
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Center stand from a shaft drive is different, it may bolt up, but it won't be right
Past; 78 kz1000, 83 kz550
Andrew
First KZ project…. 1980 KZ1000 12 Nov 2016 09:12 #747818
  • JOE MKII
I have been looking for a factory service manual for this bike and I am confused, theres a lot of them out there but none seem specific to the 1980 KZ1000 A4 / MKII. I am not opposed to the downloaded ones but I do prefer a actual manual.
Any advice on factory service manuals would be appreciated, and I did search the site but Im still confused :unsure:
Also I believe I am missing this piece of the air box, I know the bike ran well in the past as it is but i am looking for advice..Replace or leave it out. I know all the trouble jetting can be without a complete air box,I have done A LOT of jetting with pods, some of it actually succefuly :laugh: I am going to be using the air box that attaches to the carbs for sure so its just the air intake that would be missing.
First KZ project…. 1980 KZ1000 12 Nov 2016 16:13 #747831
  • floivanus
There's a supplement for the mkII out there, not a full manual if I remember correctly.
The air box silencer is almost never with the bike, most people ditched them when they pulled the battery out for storage, or because they didn't want to hassle with them.
You'll be fine without it, if you find one you can put it on later, they don't come up often, and you'll be lucky to find one for $100.
Andrew
The following user(s) said Thank You: JOE MKII
