Finally had some time to take pictures of valve stems and faces + take measurements of the pistons, rings and bores. I don't have a micrometer, so all measurements are from feeler gauges and a digital caliper. Where one size on the feeler gauge felt too lose and the next size up felt too tight, I split the difference. Here goes...
Piston 1:
Outside Diameter 69.85mm
Clearance in bore 0.045mm
Ring 1 gap 0.4mm (clearance in groove 0.045mm)
Ring 2 gap 0.35mm (clearance in groove 0.045mm)
Ring 3 gap 0.7mm
Ring 4 gap 0.65mm
Piston 2:
Outside Diameter 69.83mm
Clearance in bore 0.04mm
Ring 1 gap 0.6mm (clearance in groove 0.05mm)
Ring 3 gap 0.7mm
Ring 4 gap 0.9mm
(OUTSIDE LIMIT - IS THIS AN ISSUE?)
Piston 3:
Outside Diameter 69.87mm
Clearance in bore 0.06mm
Ring 1 gap 0.3mm (clearance in groove 0.065mm)
Ring 2 gap 0.35mm (clearance in groove 0.04mm)
Ring 3 gap 0.65mm
Ring 4 gap 0.6mm
Piston 4:
Ring 1 gap 0.35mm (clearance in groove 0.065mm)
Ring 2 gap 0.4mm (clearance in groove 0.04mm)
Ring 3 gap 0.7mm
Ring 4 gap 0.7mm
As far as I can tell, these measurements are all within the wear limits, except for the ring gap on ring 4 in piston 2.
And pics of the valve stems/faces, they're all in the same condition, pretty much...
