Dutch 1977 Z1000 Build 05 Aug 2016 07:17 #737520
  • Wiers
  • Wiers's Avatar Topic Author
  • Thank you received: 21
Thanks guys, for the kind words and usable information.
The rollerblade wheels look great on the bike Leon, I gues one of them has a spring or something like that to keep tension on the chain?
Eric
Last edit: by Wiers.
Dutch 1977 Z1000 Build 05 Aug 2016 07:20 #737521
  • Wiers
Look what UPS dropped off at my hotel
Dutch 1977 Z1000 Build 05 Aug 2016 07:26 #737522
  • Wiers
I need to enlarge the hole in the D&G plate because I will be installing a hydraulic clutch.
As for the low breather cover I have no idea yet.
It looks nice on other builds but I don,t know yet how tho replace the old one with the new lower one.
Can I just remove the small pipes which are under the high cover and put the low cover on it with a tube?
Eric
Dutch 1977 Z1000 Build 05 Aug 2016 09:02 #737539
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2611
Purdy. That's the idea on the breather cover. They sell clutch slaves that will bolt on to the existing hole pattern.
Dutch 1977 Z1000 Build 05 Aug 2016 09:47 #737542
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
yes the one on the bottom has spring to load it against the chain.
i modded the dg plate like you have to fit a zx7 master for kzr member benhurmx.
keep us posted,
Last edit: by 531blackbanshee.
Dutch 1977 Z1000 Build 05 Aug 2016 13:54 #737567
  • Wiers
I have a same master to fit on the plate.
Did you have to modify the pushrod Leon?
Eric
Dutch 1977 Z1000 Build 08 Aug 2016 00:08 #737793
  • Wiers
Trying out if it fits.
Seems like a big gap I need to fill otherwise everything will be splattered with chain oil.
But we have another nice shiny piece of art :lol:
Dutch 1977 Z1000 Build 08 Aug 2016 12:06 #737860
  • 531blackbanshee
  • Vendor
yes the pushrod has to be shortened.
i'm not sure how much yet :whistle: .
Dutch 1977 Z1000 Build 09 Aug 2016 11:09 #738011
  • Wiers
Before taking it apart had to make sure it was straight B)
Did not know an easy way of measuring up something which has not a straight part on it.
So with the help of gravity and a few strings I made something up and are happy with the result.
Also fixed my license plate holder.
Dutch 1977 Z1000 Build 09 Aug 2016 18:20 #738043
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
Welcome Eric.
I will be watching your build with interest.
Please add some pictures when your finished, out and about around the countryside.
Love to see some pictures of The Netherlands.
I was born there, but came to Canada with my family at a very young age.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Dutch 1977 Z1000 Build 10 Aug 2016 05:21 #738095
  • Wiers
Thanks Rob,
It will be a while before the finished pictures in the country side will appear.
By that time the summer will be far over.
Not that there will be much difference outside :pinch: ay the moment it is 17 degrees Celsius and raining.
Next week my job brings me to Toronto, 27 degrees and sunshine I see.
Eric
Dutch 1977 Z1000 Build 10 Aug 2016 05:33 #738096
  • Wiers
I have seen people struggle with hoisting the block out of the frame.
Now I know what a pita it is.
But I did it whit the help of my wife :)
Putting it back freshly painted is something else.
