Hey there Cats and Kittens!
It seems like this may be the last or close to last post for this thread. I was working on KZombie today and put the last of the puzzle pieces together. I know there will be more fine tuning or even not-so-fine tuning to do but she's pretty much fait accompli now.
I started early again to try and beat the heat, by cutting small points from steel for the seat pan's upholstery anchors:
I know they're not pretty but they're not going to come loose ever. I still have to dress-up the lower pan side with some rust inhibiting paint and was thinking of using POR or KBR since UV light won't be an issue here.
So that was one of the last delays as I couldn't find my shears all week and it was just Friday I stumbled upon them in another moving tub stacked in the corner.
Next was to finally get the new seat cushion and cover installed.
During the week, I had test fitted the new foam and cover and discovered how much tension would be on the vinyl once it was installed and showed the situation to my darling better half. She didn't think the vinyl would hold up to such stress and could possibly tear out or tear away from the cleats or points. It was her idea to put a strain relief in place as the seat was being installed. I just happen have a small role of bailing wire (you know, on the shelf next to the bubble gum for all major repairs in life; right?) and she thought it should be good enough.
Here's the seat being installed onto the pan:
The idea here is that the vinyl is sorta' wrapped around the wire and tucked inside before the vinyl is pulled snug and pressed down over the points. This means the stress or tension of the cushion foam is held in check by the wire instead of just the vinyl.
And...
It worked!
Yeah, I know... Ack! What was I thinking with that seat?
I can hear the gasping from here but frankly, I like it and it's comfortable. Not boy racer cafe style but definitely my speed and it has space on it for a passenger or a spiderweb cargo net.
So that was pretty much the final job. I installed the emblems, although the side badges remain an issue for me. I've been trying to find a printing service that can do vinyl printing in multiple colors because I designed a side panel badge to replace the stock one that is on now. So far, I've contacted a few companies but the limited run of just 2 or maybe it's the number of colors or the small size; I get no response to my queries. Here's the side emblem for grins:
and Devin, I think I'm groovin' on your idea with the red pinstripes on the wheels but it'll come down to my ability to pull off such a thing with paint that I can match instead of the wheel sticker system I've seen. On the bright side, I found a local pin stripe artist who's work looks very good so I may just suck it up and ride the bike over to his shop and leave it to someone more skilled. We'll see.
Yeah, so that's pretty much it.
I was going to fire-up the engine today after I got the seat done and the tank's fuel cap and petcock replaced but I ran into a small snag that I was totally blinded by - the battery. I discovered that my battery which I bought almost 10 years ago and promptly forgot about is just about 1/4" too tall. Yep. Soon as I installed the seat and went to close it I was like
Guess, I have a perfect, recently filled with acid and charged garage battery now and will have to go out and buy another more appropriately sized one soon.
I have some time on my hands yet before I can test ride it anyway because I am waiting on the chain rivet tool to arrive. Originally, I was going to just take this job to "the pro's" who have the tool but then learned that my local motorsports shop doesn't have the tool? I dunno how a motorsports shop could operate without such a motorbike specific tool but apparently they do. Well, the guy said it was actually the chain size that was the problem for them. He told me I would have to take it to the Harley dealer in town.
So tomorrow, I'll be removing the seat, pulling the fuel tank off again, plugging the vacuum line from the carbs and hooking up a life support I.V. bottle of gas and see what happens with the engine. I really wanted to accomplish this today, erm, yesterday now but I had lawn duty and the heat was cranking up to the point even my dog didn't want to be outside.
Oh. I discovered that my rear master cylinder is leaking a little. Seems it drips brake fluid straight down the input shaft off the brake pedal and onto the garage floor. I found a loonie sized (dollar coin) spot this morning as I backed it out into the driveway. Funny or odd that it took over a week since I bled the brakes for it to leak enough to drip off the bike. Hopefully, the master cylinder rebuild kit doesn't turn into the fiasco that the petcock ultimately became - another one year only part, made by a back-up, not recorded, supplier kinda' nightmare.
With luck guys and gals. Next report will be a ride report! Fingers crossed
