Its been awhile since i have updated my project but in need of some help. Since then, i pulled the engine from the frame. Currently im in the process of swapping the valve stem seals.
Attachment 01.jpg not found
Removed valve cover, cams seems to be in good condition.
Attachment 02.jpg not found
Removed cylinder head, noticed alot of carbon build-up. Cylinder 1 (far right in pic) spark plug was constantly fouling with oil, seems to be worst.
Attachment 05.jpg not found
I was told to check the piston rings and possibly replace them while inside the engine. Not sure how to tell if they are bad or not? The cylinder walls seems very smooth just alot of carbon build-up on top of the piston.
Attachment 03.jpg not found
Attachment 07.jpg not found
Attachment 06.jpg not found
My questions are..
1. How do i remove these valve lifters without the special tool? Would a small suction cup work? Dont have one on hand.
Attachment 04.jpg not found
2. Whats the best way to remove all the carbon build-up from pistons and cylinder head?
3. Do my piston rings need to be changed?
I will prob have more questions once im messing with the valves more.
