1978 KZ400 B1 - Scramber to be 22 Feb 2017 06:13 #754812
  • diggerdanh
  • diggerdanh's Avatar Topic Author
  • Thank you received: 89
New footpegs look great but I unfortunately ran into another misplaced bolt by the PO. I only have one front footpeg bolt. I spent most of the free time I had trying to hunt it down so I did not get much else done. I hope to stop by the hardware store today at lunch to round up another pair.
However I did get the speedo and tach ordered. I'm going with the same 2.5" black pair from Dime City Cycles that I used on my 76 KZ400. They look the part and the small size in addition to the speedo having integrated dummy lights really cleans up the front end of the bike. They should be here before the weekend. So I'm hoping that by the end of the weekend I should have the gauges in place and everything electrical on the bike will be complete.
1978 KZ400 B1 - Scramber to be 01 Mar 2017 07:52 #755509
  • diggerdanh
Small update so I don't lose any steam. I got the front turn signals mounted and the new speedo and tach mounted. The turn signals were mounted to the forks using a cheap pair of headlight ears that I trimmed down. I mounted the gauges using the stock bracket but trimmed it up a bit and modified it to sit under the mounting holes of the top triple instead of above them. I have not wired up the front turn signals or the gauges yet, that will be my chore this week. The turn signals should be easy, just need to crimp on a few bullet connectors so they mate up to the factory harness. The gauges will be a little more difficult. I've cut off the wiring and stock connectors from the original tach and speedo and I'll need to splice and solder the wires from the new gauges together with those so they will plug into the factory harness. I did the same thing (used the same guages) with my other KZ400, though I bought another set of gauges off ebay to sacrifice the connections so I could keep the old stock ones which were still nice. The stock gauges for this bike are not in good shape so I don't mind cutting them up. I'll post pics once I have everything wired up and looking good.
I had my mind set on buying a new pair of VM28s since I had a pretty good experience switching over to VM30s on my other KZ400. But now I'm rethinking that a bit and may try using the original CV carbs first and building an airbox under the electronics tray. The PO said that the had inspected the diaphragms and intake boots and they were in good shape. I can always switch over to the Mikunis if the stock carbs prove to be troublesome.
1978 KZ400 B1 - Scramber to be 02 Mar 2017 05:44 #755585
  • diggerdanh
Front turn signals and gauges are wired up and everything appears to be working properly.
Popped the tank on just to make sure it fit properly over the bundles of wiring.
How I mounted the front turn signals - the cut down cheapo headlight ears turned backwards so the lights are behind the forks. The mounting hole is way too big for the small stalk of the turn signals but a large fender washer on each side fix that. And an old lug nut works well as a spacer:
Gauges in place:
Lights on. The back light is different between the speedo and tach - much brighter on the speedo than the tach, I'm not sure if it bothers me yet or not. Rather than buying them both from the same source I bought the tach from a different place to save $10. Guess they were not exactly the same.
I still need to make a bracket to go between the speedo and tach as both are only mounted at a single point,
The LED headlight is pretty bright, though I have not tried it outside yet. New technology but old school look.
1978 KZ400 B1 - Scramber to be 02 Mar 2017 05:46 #755586
  • diggerdanh
Couple more. In the top pic you can see the MX style footpegs.
Last edit: by diggerdanh.
1978 KZ400 B1 - Scramber to be 02 Mar 2017 05:54 #755587
  • diggerdanh
Next up is to clean and inspect the old carbs, intake boots and airbox boots, figure out what I'm doing for an airbox, mount MX number plates as side covers, and make some modifications to the stock seat pan.
If the old carbs work out then my remaining spend for this bike is just new cables and fabricating the exhaust. That would be great.
1978 KZ400 B1 - Scramber to be 02 Mar 2017 06:18 #755590
  • kzcurt
  • kzcurt's Avatar
  • Thank you received: 21
Really nice look you have going there!
Flag carrier #23
9 @ 50-2053,
The following user(s) said Thank You: GPz550D1, diggerdanh
1978 KZ400 B1 - Scramber to be 06 Mar 2017 07:39 #755910
  • diggerdanh
Did not get as much done this weekend as I had hoped. I did get some modifications done to the seat pan to fill some gaps at the rear so it follows the frame better. That is also now devoid of rust and primed and painted. I also got some brackets for the side panels cleaned up, primed and painted. I hope to figure out mounting for the MX number plates as side panels this week. I'll also be on the hunt for seat padding and a seat covering. I used black leather from an old coat I picked up from Goodwill for my last bike. I plan to do something similar this time too.
I set about disassembling and inspecting the stock carbs yesterday and everything appeared to be functional and pretty clean inside though they will need to be split and completely disassembled replacing all gaskets, o-rings, etc. And I was disappointed that while one of the diaphragms was in good shape the other had quite a sizable hole in it. So I set everything aside and began to think about whether to buy gaskets, o-rings, and diaphragms for the old carbs or go ahead and move to Mikuni VM-28s. I'm still debating this.
1978 KZ400 B1 - Scramber to be 09 Mar 2017 06:25 #756229
  • diggerdanh
More small updates.
I still have not completely decided on repairing the old carbs vs buying VM28s. I'm leaning toward the VM28s though - after some calculations I should be out only about an additional $50 or so going with the Mikunis. And that's assuming that all the old carbs need are diaphragms, gaskets and o-rings and will work well after that.
In the meantime I have modified the stock seat pan and test fitted it to the bike and mounted the MX style side covers. The stock pan is not flat at the rear like in this pic, it bends upward at maybe a 30 degree angle because the 78 uses a tail piece. I did not get the tail piece for this bike and really did not want to use it anyway. I cut some reliefs in the side of the pan at that step and bent the back down to be flat. I then cut some strips of sheet metal, you can see where it is riveted to the pan in the pictures, to fill the gaps so the sides of the pan followed the frame rail better. I found the hinges and latch and latch plate in the boxes of parts and it is all fastened together as it should be. There was some surface rust on the pan but a wire wheel cleaned it up and a couple coats of rustproof coating and it looks good.
With the seat pan in place I was finally able to sit on it and make vroom-vroom noises :) - I even stood up on the pegs and balanced it a bit. This bike is pretty light, I cannot wait to ride it around the fields in the back yard and get it muddy.
All the brackets are still in place for the original side covers, so I could go back to them later if I'd like, but I like the slim look the number plates give it. They are mounted using a bolt through the bottom grommet for the stock side cover and a p-clamp at the top of the frame rail. The plates will have a number on them, they'll have a white background with red trim and black numbers - I'm thinking 78 since the bike is a 1978 model.
Next up is to get some foam and create some seat padding and then find some suitable black leather to cover it.
1978 KZ400 B1 - Scramber to be 10 Mar 2017 03:12 #756309
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Looking good Dan. That is going to be a fun bike.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
1978 KZ400 B1 - Scramber to be 13 Mar 2017 06:22 #756617
  • diggerdanh
Did not get a lot done this weekend but I did acquire some foam for seat padding and a black leather jacket that should make a nice seat cover if it fits, it will be close. I glued the layers of foam to the seat pan last night. Hope to start shaping it this evening.
Tip: these reflectors are a good replacement for the originals on the front of the frame under the tank, they screw right in. The pattern is a little different from the stock ones but at $5 each they are (for me) a better option than the $20-30+ each I saw people asking on ebay for NOS or even used take-offs.
Chris Safety Products 2-1/2" stud mounted round amber reflector: amzn.to/2nloIvI
1978 KZ400 B1 - Scramber to be 15 Mar 2017 06:33 #756781
  • diggerdanh
Seat shaping underway. I have no idea what I am doing - I'll just keep faking it until it looks right.
When I first put the layers together I put way too many layers of the base layer and the seat was much too tall. I ended up having to cut out everything but the first 2 layers - which explains why the top layer of soft white foam is cut into sections. But I think it is a mistake I can overcome. They should all glue back together well enough. This is much closer to the profile I am looking for. After nearly two hours of shaping it is getting close but still probably a couple more hours to go - it will be perfectly smooth (or pretty close) when I am done.
Test fit of seat cover. It is not pulled tight, just on loosely to make sure it would fit. It should look less like a big black brick once the cover is stretched tight and fastened down... hopefully. If not then I'll take the cover back off and continue shaping until it looks good.
After test fitting the cover I found a couple of soft spots in the padding that need additional foam added. And I'll need to add a more foam at the front where the seat meets the tank so it does not drop off so drastically.
1978 KZ400 B1 - Scramber to be 15 Mar 2017 09:15 #756797
  • diggerdanh
A couple of weeks ago I started thinking that the euro-style handle bars that I am using are too low and do not have enough sweep at the ends for the style of bike I am going for. I tried to set those doubts aside but it has been eating at me every time I see a pic or look at the bike. I think it really needs a set of vintage looking MX/desert style bars. And I'm thinking of going chrome with them instead of black. I've fought that doubt as much as I can and I've given in - I just ordered a set of vintage looking bars that should be perfect. They have a 5" rise and 5" sweep versus the 2-3" rise and sweep the current bars have and they also have a crossbar. Unfortunately that means that I will probably need to order a new stainless brake line - I don't think the current one will be long enough, I'll have to wait and see. But on a more positive note the stock throttle and clutch cable lengths should work well with the new bars so I will not have to order them in custom lengths.
I'll be able to switch the black euro-style bar that is currently on it to my 76 KZ400 to replace the chrome superbike bar that is on it now. Additionally if I do need to buy a new brake line then I'll also use the current one on the 76 to replace the original rubber hoses. I'll just switch from the stock brake splitter/switch to a banjo bolt with a brake switch.
The following user(s) said Thank You: Tomcat57
