650ed wrote: STOP!
You need to buy and read the manual BEFORE messing up the engine. You mention " flywheel puller, new washers, new exhaust, next exhaust gaskets, new split collars, etc." and " I'm thinking i have to get a rotor tool that doesn't exist, an impact wrench, a gear puller/pusher I can't find..."
None of that stuff has anything whatsoever to do with replacing the starter clutch in your bike, so what exactly are you trying to accomplish? Ed
I'm sorry ed. My post probably wasn't clear, I was pretty frustrated last night and was venting. I do have the FSM, that's actually what has me worried, because in reading it, it says I need a special alternator rotor tool 57001-308 and a special gear puller/pusher tool 57001-319. Both of these tools are obsolete...
As far as everything else I mentioned, I was told I would need the flywheel puller, or could use rthe rear axle, in a starter clutch thread. So I bought the 18x1.5 flywheel puller tool. I was told I would need to replace the clutch thrust washers, so I bought those (I also bought new starter clutch spacers), I was told I was going to have to remove the exhaust to do the job, so I bought a used v &h 4 to 1, and the appropriate exhaust gaskets and split keepers to install said exhaust.. The bike already had pods, but had yet to be jetted for them, so I bought 70/140 jets..
I've been reading that I'll need an impact wrench to get the clutch bolt off, and possibly the clutch basket tool...
However my mail worry is the special tools. 57001-308 is designed to hold the alternator rotor, preventing the secondary shaft from spinning while you break the bolt free, and gear puller pusher 57001-319, is used to remove/replace the secondary shaft gear from the shaft.
Will I even have to do that? The FSM says I will, but maybe its instructions are for replacing all the parts, and I'm just trying to replace the one way starter clutch assembly and gear?
Alsoci just now noticed in the instructions it says I'll need a bearing driver tool 57001-297 to reinstall.
Its the FSM that has me confused...
