Garage Queen - 1978 KZ650 30 Mar 2015 07:42 #665772
  • Dolby67
  • Dolby67's Avatar Topic Author
  • Thank you received: 0
Found myself a nice KZ650 last weekend. I was going to make a bobber out of it , but it is so perfect and clean that I just cant do it. Going to keep it all stock and make it shine like new.
Whats wrong with it - the carbs could us a rebuild. After that - I really dont know. Other then polishing it up and replacing some rubber. But we shall see. I took the pipes off to polish them up. No dents , no dings, and it was never layed down. has 2,590 miles
Attachment FullSizeRender.jpg not found
Last edit: by Dolby67.
Garage Queen - 1978 KZ650 30 Mar 2015 07:54 #665773
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
  • Thank you received: 23
shes a beauty!!! really like the color!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
Garage Queen - 1978 KZ650 30 Mar 2015 08:49 #665780
  • Thank you received: 2828
That's an AMAZING find!!! I'm really glad to see that you do not plan to modify it. The are precious few stock KZ650-C2 bikes still in existence. It's beautiful with the original paint, etc! If you have any questions or run into any problems be sure to ask on this forum. There are plenty of knowledgeable folks here.
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
The following user(s) said Thank You: AlexDeyo, Dolby67
Garage Queen - 1978 KZ650 30 Mar 2015 11:59 #665798
  • Dolby67
Thanks, those are GREAT tips!
Garage Queen - 1978 KZ650 30 Mar 2015 13:44 #665807
  • azman857
  • azman857's Avatar
  • Thank you received: 111
That is a great find! Thanks for doing her right and not modifier her to bobber. She's a beauty as she is. No harm in a few updates in voltage rectifiers/regulater, lights or anything not permanant in frame or etc.
Garage Queen - 1978 KZ650 30 Mar 2015 19:36 #665867
  • Dolby67
So Im putting the gas tank back on - and I see this
Attachment IMG_2275.jpg not found
Where dis my fuel line hook up go. I'm I imagining things?
Garage Queen - 1978 KZ650 30 Mar 2015 19:39 #665869
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2611
Is the fitting still in the hose?
Garage Queen - 1978 KZ650 30 Mar 2015 20:31 #665879
  • Dolby67
Nope.
I didn't know it could come off.
Maybe I'll get a brass fitting and Jb weld it in
Garage Queen - 1978 KZ650 30 Mar 2015 20:39 #665882
  • SWest
  • SWest's Avatar
  • 10 22 2014
They are a semi press fit. You could try that but a new one would be better.
Garage Queen - 1978 KZ650 01 Apr 2015 06:13 #666026
  • jmparish159
  • jmparish159's Avatar
nice find! I just subscribed today. I have a 1979 kz400 which I will post pics of as soon as I upload them from my phone. ive run into an issue with my clutch. I got excited changing out my handlebars and instead of taking the clutch cable apart at the bars, I just forced it off the sides of the handlebars. when I slid them off I heard a pop down in the engine somewhere. clutch cable is still intact, but I ordered a new one anyway. once I tighten it down the clutch doesn't keep up pressure. any advice? thank you
Justin P.
Garage Queen - 1978 KZ650 01 Apr 2015 09:49 #666049
  • SWest
  • SWest's Avatar
  • 10 22 2014
There is another thread on this but adjust it at the cover.
Garage Queen - 1978 KZ650 01 Apr 2015 19:41 #666148
  • Dolby67
Okay...well, i got the pipes, tank , and seat on.
new plugs too.
Tried to start it and .....no go. Almost had it going but the battery started to die
It ran for 5 sec. and then stopped - it smelled like old gas and dust. LOL
I added seafoam to the high octane gas...and going to let it sit in there for a bit and try again tomorrow.
Wish Me Luck
