  • Page:
  • 1
1985 GPZ750 project: lots of questions 01 Dec 2014 13:55 #655086
  • taylee
  • taylee's Avatar Topic Author
  • Thank you received: 1
I just picked up a 1985 US model GPZ750 (25K miles) that has been sitting outside for 8 years. It's going to need a lot of work. And I'm going to need a lot of advice and help in getting it up and running. I've put together some initial cursory questions I hope you all can help me with:
1. Is it worth getting rid of the airbox and going to individual filters? I've heard on other bikes it can cause flat spots and carb tuning issues.
2. Is it worth buying a bike specific jet kit? The bike currently has the stock exhaust.
3. I plan to perform a leak down test on it and take the head off to replace gaskets regardless.
Are there any tips tricks, or things I should do while I have it off?
Besides a big bore kit (which I don't have money for) what is the hot ticket to get a bit more oomph out of this engine?
1985 GPZ750 (non-turbo)
Last edit: by taylee.
1985 GPZ750 project: lots of questions 01 Dec 2014 14:17 #655089
  • Zephyrrider
  • Zephyrrider's Avatar
  • Thank you received: 50
Thats a better pic
Stick with airbox,
Stay with your standard carb setup - keep it simple for a start - get it sorted,
Thats motorcycle abuse letting it sit outside for 8 years - just appalling : )
Mick
1994 ZR750 Zephyr C4.
1985 GPZ750 project: lots of questions 01 Dec 2014 14:59 #655095
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
First & most important is to get a KAWASAKI service/shop manual, for your specific year & model bike, don't waste your money on a Haynes or Clymer manual ....go thru the maintenance procedures in the manual, if it's been sitting outside for 8 yrs. chain & sprockets are toast, brake fluid , oil, fresh fuel , fork oil carbs cleaned, ETC.
stay with the stock airbox & pipes, tires are probably shot too
once you go thru the maintenance procedures & get her running properly, you'll be surprised on how much oompf, that bike has
Pete
1985 GPZ750 project: lots of questions 09 Dec 2014 15:01 #655711
  • taylee
If the stock GPZ fork length is 31 inches (approx) and most sportbike front ends are 28-28.5 PLUS they run a smaller rim diamater and low profile tire (another 1 inch difference from the GPZ); how are guys getting away with running an updated front end that is essentially 3-4 inches shorter than the stock one without doing a custom drop down triple clamp? And can even a gull wing top triple clamp give you 3-4 extra inches?
1985 GPZ750 project: lots of questions 09 Dec 2014 16:21 #655725
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
750turbo.com :evil:
1985 GPZ750 project: lots of questions 09 Dec 2014 16:32 #655727
  • taylee
Yes I'm on there too.
Ok so anyone have any leads on fork extenders like these?
1985 GPZ750 project: lots of questions 10 Dec 2014 03:35 #655747
  • kawi810
  • kawi810's Avatar
  • Thank you received: 11
since you are a member on 750turbo download the base manual you will need it .do some looking on there they have done a lot of front and rear swaps.i am rebuilding my 8100cc gpz as we speak .it sat for many a year in storage.so now i am gathering all the parts for the rebuild any questions just ask been playing with these bikes for 30 years.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • Page:
  • 1
