Alex.... whatever transpired between you and Pittstop is none of my business. I will state without any hesitation that Joe Hooper has been a solid, proven individual and businessman with many members of this forum. In fact, If I'm too busy to build an engine or if during a phone call with a potential customer I discover they are close to Joe's shop, I have referred them to Joe because it just makes sense.
Also, J motors were oil leaking mothers right from the factory. That's a fact. I worked on those things when they were brand new, under warranty. Oil leaks were an everyday issue with them. Head gaskets were especially troublesome. That's not to make excuses...it's just plain truth.
I wish you success with your situation. I suggest a good sealant on all gaskets in that motor. Permatex Moto Seal is a very good product. Very similar to Honda, Kawasaki or Yamabond but commonly available and priced reasonably as well. I recently built a 1428 on a KZ bottom end and those things can be troublesome with oil leaks at the base & head surfaces. I used sealant on both surfaces. After a full season of hill climbing it's still dry... so I know for a fact that stuff will do the job...
Also Immediate retorque o the head aftger the first heat cycle is an absolute must. Fire the engine. Bring it up to temperature by running it for several minutes. Shut it down and let it get STONE COLD. Then go over the head nuts an bolts again with a torque wrench. I would repeat that after 100 miles.... it certainly can't hurt.
If Joe is sick as was mentioned I wish him a speedy and full recovery...
Larry C
Hey Larry,
Thank you very much for your advice. I'm not a machinist, but a new-car technician who's been sealing, assembling, and diagnosing engines for a lot of years (mostly with GM, so I know leaks). And the no-doubt facts are, if a head or block deck isn't flat (out of specs) it's gonna leak. If you paint gasket surfaces, they're gonna leak. That's what I dealt with on this rebuild. I had the decks machined flat, cleaned off the paint, used OEM gaskets -- and the top-end, all the engine covers and the pan, no longer leak, at all.
These air cooled engines are a bit different than a car. On a car, as long as the coolant system is functional, and the fans are working, you can sit there all day in the middle of the summer and never go above normal operating temperature. On an air cooled bike, stuck in traffic for a relatively short period of time, temperatures skyrocket and aluminum warps.
I think that might be a big reason behind head gasket leaks on a lot of these engines. And trying to reseal without precision machining, can be like paddling upstream. I've learned from other folks that I should have also pulled the jugs and machined the bottom of the block, but I think I may have gotten away with that one.
The only sealant I used was Hondabond around the cam plugs, and likewise if I ever get the time and split the case to fix the final leak. Kawasaki gaskets are expensive, but thicker and coated with a sealant film.
Also learned something from a buddy who did a lot of years working on all the CHPs KZs. I used the OEM 1100 head gaskets on my engine with the 1075cc kit to compensate for the wider bore. It worked great!
I've learned a lot about the "J" engine though this whole process, and it's made me appreciate them even more.
