CSR1000 Project Build 27 Mar 2015 13:27 #665423
  • davido
  • davido's Avatar Topic Author
  • Away
  • Thank you received: 286
So,next was putting it all together again
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 30 Mar 2015 06:44 #665766
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
nice progress sir!
CSR1000 Project Build 31 Mar 2015 11:19 #665934
  • davido
  • Away
Thanks Leon. Next thing is to get the tail light mounted. I bought a bit of 4mm alu plate to form a mount. I want to get the ZXR light tucked in nice and tidy.Ive also got to weld on something to fix the tailpiece down to the frame. Thatll be my weekend.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 07 Apr 2015 12:51 #666973
  • davido
  • Away
A couple of tabs welded on to bolt the seat down to
I didnt have enough room to fit the tail light and mount ,nicely under the tailpiece ,so, I had to whack the back hoop off again and shorten it even more..Also I shifted the mounting plate from under the hoop to over the hoop so I can get the tail light tucked in with the minimum of gaps.Unfortunately,with all the grinding and welding,I really thinned the steel on the hoop in places to the extent that I was blowing holes in it as I tacked it up.
Off to my local friendly bike shop again,to get the damage assessed..The result was a 2mm steel plate welded over the bottom of the hoop.
That should keep it from getting too wobbley.
I think (hope)thats it now for the welding.The frame is as ready as its going to be.Tail light mount and the number plate mount are next. Ive got some alu plate downstairsand ,hopefully,I can get that sorted tomorrow.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 08 Apr 2015 11:24 #667125
  • davido
  • Away
Alu plate for the Tail light mount.
Knocked up a bendy machine
If I was to do it again,I would make a shallow cut on the inside of the bend to get a sharper 90 degree angle. They all came out a bit rounded. Live and learn.
Heres the bike as it stands now.The lower part of alu plate will be cut back and bent out to hold the number plate.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: by davido.
CSR1000 Project Build 08 Apr 2015 11:44 #667129
  • 531blackbanshee
  • Vendor
oh yeah!
coming right along :evil: ,lookin good.
keep us posted,
CSR1000 Project Build 09 Apr 2015 06:02 #667235
  • davido
  • Away
a bit more alu plate work.Something to hang my clocks on.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 09 Apr 2015 06:13 #667236
  • 531blackbanshee
  • Vendor
that worked out nicely! :evil:
CSR1000 Project Build 14 Apr 2015 04:51 #667877
  • davido
  • Away
Well Im just playing here really.Im not sure what I want to do. The tail light mount didnt turn of as i expected but I thought It was ok and itll do.Now Im in 2 minds.Ive bought another piece of alu plate and I think Ill have another go at it.If I cut into it,opposite the bends,I should be able to get a sharper bend on it.I hope.
Also had a go at a making headlight mount.The original wont fit on the ZXR front
So I bought some pipe hangers from the local plumming shop
I bent some steel bar ,threaded the ends and welded a couple of washers into it
and came up with this
Dont know if iI like them or not.I think theyre a bit too big so I might trimm them down a bit and look again.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 14 Apr 2015 04:54 #667878
  • davido
  • Away
No eBay APP ID and/or Cert ID defined in Kunena configurationAlso,I went for it and ordered these;
with a complete set of seals etc.
No more pitted pistons and rusty seized calipers.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 15 Apr 2015 09:04 #668047
  • davido
  • Away
OK,I couldnt live with the tail light hanger,so, I had another go
New on on the left,old one on the right
I cut a 1mm slot on the inside of the bends which made them sharper
It looks a lot cleaner alround now.
I also ordered some new brake hoses today.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 15 Apr 2015 12:13 #668075
  • 531blackbanshee
  • Vendor
i hate having to redo stuff.
but i hate it worse if i don't !
then it just glares at me everytime i see it.
good job on the remake sir!
