Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 00:02 #600038
  • lucienmaier
  • lucienmaier's Avatar Topic Author
  • Thank you received: 3
So I bought with a old engine on her. And a spare blown engine. I worked hard for a couple months and brought her back to life. I was about 1700 miles into the season when my number 1 piston went...
So I sat with my dead bike and was very sad, and then a buddy proposed a wild idea. Take the jug off a 1100. And the piston off a different 1100. At first I did what you just did...
But I have done my research and ordered my parts....
So you all get to see how it turns out...
Here's from a ride we did right before she blew number one...
--1981 Kz1000m CSR--
--Converted to 1100CC---
Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 00:04 #600040
  • lucienmaier
Oppps
Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 00:10 #600043
  • lucienmaier
and now... this hurts a little....
Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 06:17 #600059
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 303
Yep...that second photo is a big ouch.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 17:43 #600116
  • lucienmaier
starting on my bench tonight. (I need a good place to build the engine.)
The gaskets have arrived,
pistons and jug should be here Thursday....
Mad science, 4 engine into 1 with 100cc upgrade 06 Aug 2013 19:31 #600142
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
OK what actually happened to #1 piston?
Mad science, 4 engine into 1 with 100cc upgrade 07 Aug 2013 17:08 #600308
  • lucienmaier
not 100% sure.
But the piston was pretty much destroyed in the cylinder. All of the offending parts are being replaced, plus some :D
Mad science, 4 engine into 1 with 100cc upgrade 15 Aug 2013 15:29 #601576
  • lucienmaier
cases are now both out and starting to disassemble to get things rolling.
Mad science, 4 engine into 1 with 100cc upgrade 19 Aug 2013 22:50 #602233
  • lucienmaier
And screeching halt...
So I need a crankshaft on inspecting it I find that my rod is bent....
(That's what's she said)
So the search is on
1981 kz1000m csr crankshaft assembly needed :|
Mad science, 4 engine into 1 with 100cc upgrade 06 Sep 2013 15:41 #605232
  • lucienmaier
Crankshaft is on the way. I should be starting the build this next weekend!
Mad science, 4 engine into 1 with 100cc upgrade 07 Oct 2013 11:59 #609095
  • lucienmaier
Crankcase went together this weekend! we tested out the top and it looks like all should work with the modifications to the engine (1000 to 1100 cc) The exhaust value don't have much play but should be alright. rest looks good. should be building out the rest of the engine this week :D
Attachment case.jpg not found
Mad science, 4 engine into 1 with 100cc upgrade 09 Oct 2013 21:31 #609428
  • peavylotus
  • peavylotus's Avatar
  • Movin on up
  • Thank you received: 15
Nice work. Post more pics, it is a build thread haha. What pistons are you going with?
1980 KZ 1045 LTD Currently Workin' It Out
