My 2000 KZP project bike! First timer, but all out
- tucsonKZ1kP
Motor was pretty beat up...
- Thank you received: 796
hth,let me know if i can help you.
- Hollywoodmx
- Thank you received: 16
You are going to have to give more details of what your challenged with for people to help.
CRAZY clean garage BTW!
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- tucsonKZ1kP
Rear swingarm: 2002 GSXR1000
Rear Brake: 2002 GSXR1000
Rear Shock: 2007 GSXR1000
Front Forks: 2008 KZ600P
Front Calipers: 2008 ZX14
Front Rotors: 2003 GSXR600
Front Fender: 2008 ZX600P
Wheels: Matchin 2002 GSXR1000 Wheels powder coated Gunmetal Grey
Really excited about where it's going!
- Hollywoodmx
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- tucsonKZ1kP
Hollywoodmx wrote: looking great! Maybe you are just missing your spacers but the front wheel doesn't look center.
Are you referring to the pic up earlier in the thread where there is no fender on it? If so, thats because it is... It wasnt lined up straight and will require a spacer on each side to keep it centered. Once the rotors and calipers were put on, its perfectly centered, just needs the spacers to keep everything from moving. Anybody sell spacers for this or should i just fab them?
Here's a pic of it centered....
- tucsonKZ1kP
clearwaterlights.com/infopg_glenda.html
- tucsonKZ1kP
- tucsonKZ1kP
- Haybus
- Big Al
- Thank you received: 42
Next, have you assessed what you can take out of the rear cush drive to move the chain closer to the tire? You can only shave off so much before you're into the tire. Conversely you can only offset about 5/8" on the front sprocket before you're into the frame. Good rule of thumb is to try to maintin 4-5mm clearance so the chain doesn't slap your freshly painted purdy bits.
There are many methods for figuring out the offsets. Most of the builds in the project section have a page or two about different methods. Also, be mindful of what chain you intend to use in your calculations. Not all chains are created equal. Many manufacturers state their pin length (outside chain width) on their websites. You could set up for a 530 standard o-ring, buy a fancy Xring, Wring, Zring or whatever and have it rub. Check your calculations and measurements many times before you start cutting anything.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
- Haybus
- Big Al
2005 FJR
2009 Hayabusa
- tucsonKZ1kP
