- Thank you received: 103
New Member '79 KZ1000E-ST project....
- roy-b-boy-b
That engine does not really start running until 6000 rpm. You are packing a lot of weight.
There are a lot of coils on eBay but I would order fron Jeff at Z1Enterprises. I know him and a lot of his crew personally and they are good to deal with and ship lighting fast.
Again taht is a awsome bike. I can't believe the condition it is in. I had to look twice to see the windshield.
- NovaNewfie
- Thank you received: 3
1979 KZ1000E-1 ST
- NovaNewfie
1979 KZ1000E-1 ST
- roy-b-boy-b
- NovaNewfie
roy-b-boy-b wrote: Does this bike have electronic ignition ? I would get the ignition system sorted out. The main reason coils crack is because the ignition was left on. Roy
Yes. The bike has electric ignition. I believe the coils cracked due to getting condensation in them from sitting for about 20 years. The air is damp here most of the year. I believe they are firing fine but the wires aren't the best and with them cracked I figure they should be replaced. I drove it for 30 miles the other day and it seemed to be hitting on all four alright.
I asked my Uncle the original owner about weather he had the valves adjusted etc. He said it had always worked too good to screw with it. Everything was as it came from the dealer. I replaced the original air filter the other day!!!
1979 KZ1000E-1 ST
- NovaNewfie
roy-b-boy-b wrote: Beautiful bike. I am with you,leave it like it is. I would not coat the tank,gasahol would likley destroy the liner if you were to go that route. Get a good gas filter.
Make sure you have 12 volts to the coils. I use Dyna coils on my bikes. Your coils should be good enough to start with unless they are cracked.
The clutch might come unstuck after you get the bike stated just by shifting gears while it is on the center stand. Roy
Here is a picture of one of the many handfuls of crap that came out of the tank.
1979 KZ1000E-1 ST
- DesertKZ
- Thank you received: 20
NovaNewfie wrote: I'm going to change my fork oil. Do I just remove the drain screws in the bottom and pump the forks to get the old oil out?
The manual says to remove the springs to check the fork oil, they are apparently a two piece spring with a washer in between them. Do I just pull them out and refill to proper level then re-install?
Support the bike with the front end off the ground, remove the drain screws and unscrew the tops (be careful because the springs will have some pressure on them. There's a top spring about 6" long, a washer and then another spring about 12" long. You should replace the seals but if you don't, refill and check the oil level with a wood dowel inserted through the top. The manual states what the oil depth should be.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- NovaNewfie
I bought the wrong manual. I bought the Clymer and since I haven't worked for two months I don't have the spare money right now to buy the Kawasaki service manual. The Clymer manual says the oil should be down 18.9 inches with springs removed 310ml of oil. I take it that's the amount of oil for each side?
1979 KZ1000E-1 ST
- DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- NovaNewfie
1979 KZ1000E-1 ST
- bluezbike
- Thank you received: 104
BTW as mentioned before.....your bike is really beautiful
79 KZ 1000 LTD
- NovaNewfie
I've been waiting to check the valve clearances till after I get back to work and buy the gaskets. I don't want to chance taking it apart without having them on hand.
I went through all the electrical connections with contact cleaner.
It runs rough when its cold, seems to smoothen out once it warms up and gets above 1800-2000rpm.
I plan on keeping all the extra's on it, more or less just for my Uncles sake. He put 20'000 miles on it riding two-up 95% of the time without any problem.
Thanks for your kind words as to the condition of the bike. I can see little flaws but for being an original 34 year old bike its stayed remarkably well.
I'm not really looking for performance out of the bike just a reliable old cruiser.
1979 KZ1000E-1 ST
