- Thank you received: 2103
new owner of an 81 kz 550 ltd (video)
www.kzrider.com/forum/4-electrical/17274...or-mattylight#172746
- lightitup
- Thank you received: 10
81 kz 550 ltd
- lightitup
81 kz 550 ltd
- Motor Head
- Thank you received: 393
lightitup wrote: hey everyone so it looks like im going to need some coils for her any ideas on ones i should go with i know a lot of people use dyna s ones but im on a tight budget at the moment. can i use 1992 Kawasaki ZX11C - OEM they put out 3.3 ohms. or if anyone knows any that will work let me know
If as you stated the coils measure 3.3 Ohm's across the Primary winding/ small wire terminals, they should be fine with your bikes electrical. Hopefully they can mount up also.
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
- lightitup
81 kz 550 ltd
- lightitup
would it be number 9
81 kz 550 ltd
- Motor Head
- lightitup
over the weekend i got the oil drained the dyna coils installed. pulled the chain sprocket off and need to replace it along with the chain and rear wheel sprocket any input on the different tooth ratios would help not sure which ones to get
81 kz 550 ltd
- loudhvx
- Thank you received: 1622
You may have to download it to your computer since some browsers won't let it work.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- lightitup
81 kz 550 ltd
- loudhvx
Be aware, you will likely have to get a non-standard chain length if you change both in the same direction. Sometimes you have to change the chain even when only changing one sprocket size.
1981 KZ550 D1 gpz.
Other links.
